Freezer Pro 7 Install Question
Mooserfan
7
I am installing a freezer pro seven cooler (i4670k, Asrock extreme6, Corsair 500 case). Should I install the cooler on my CPU/motherboard before I install the mobo into the case, or after? Thanks for any advice.
I would say install it on the motherboard first. Its generally easier to mount the brackets and manipulate it this way. It doesnt matter which way yo do it, just whats easier for you.
