Hi guys,
I just built my first tower, everything is fine, except for how the mic works, if it works...
I usually use headphones that have the mic attached, and I am used to just plugging it in, into the headphone jack, and both the headphones and the mic work.
I am using the Zalman Z11 plus case, and a GB 970A-UD3 mobo, so logically i use the jacks on the top. All the drivers are installed, and updated to the most current versions. I have tried the one from the MoBo's website for the sound card, and I have had it find a driver it self, but I still can't use the mic on the headphones. If I put it into the mic jack, it turns into the mic itself. I'm not sure how to go about fixing it, because I figure it should just work, like all the rest.
Help please
Help please
