Fresh PC won't POST
Torojon
I hope this is the correct place for troubleshooting. If not, please move this thread.
Specs:
  • AMD FX-6300
    ASUS m5a78l-m lx plus (AMI BIOS)
    2x4g Ballistix Sport * MSI R7870-2GD5T/OC
    XFX Core Edition PRO550W
TLDR: My PC will not POST or randomly POSTs.
I received all of my parts yesterday morning and began building shortly thereafter. I started in the case, hoping everything would go smoothly. It didn't: I attempted to do a boot test and there was no display and no BIOS beep, despite all fans running.
Next, I figured the board might be shorting somewhere and did a test boot on the Mobo box and the same thing happened. I fiddled around with the cords, making sure they were all snug and tried again. This time the BIOS gave a single beep and gave a successful POST. I had to leave for a quick work meeting and when I came back and tried to start it again, there was no display and no beep. I didn't change anything from before; I neither touched nor moved anything. I messed around with it a little and removed the RAM. Nothing. No BIOS errors.
I put the RAM back in and reversed the speaker to ensure that I didn't have it backward and it gave a single long continuous beep (for clarity: the sound didn't stop, as in there were no breaks in the beep). I don't think that's a normal AMI BIOS error, but please correct me if I'm wrong.
I'm not an expert with AMI so I switched the speaker again and put one of the sticks back in and it gave a single beep and posted successfully (I'm assuming at this point the polarity doesn't matter). I continued to power the system down and let the power drain and restart it to make sure it wasn't a fluke. After five successful POSTs, I figured one of the RAM modules was corrupted and decided to try to build it back in the case. I wanted to make sure so I switched the modules out and the PC posted successfully. I put the other stick in: nothing. It would only post with one module now (it posted with two earlier before I left for my meeting) in either of the DIMM slots. (I checked the system information in the BIOS every time and the RAM and CPU correctly displayed--I didn't check the GPU.)
I've heard that the memory controller on the mobo can be funky and also that the ram itself can cause this problem. I don't have any other components around to test, so I thought maybe it was just the RAM together and decided to go forward with the build with just one module. Once the basic components were installed again I experienced the same thing as before: no display and no beep.
I took it out again and that's basically where I'm at now. No matter what I do now, the PC won't beep or give a display.
I've experienced these scenarios as well:
No RAM:
  • long continuous beep with no breaks
    3 short beeps
    1 beep no display
1 stick or 2 modules of RAM:
  • Stuck at BIOS flash screen
    1 beep and no display
    no beep and no display
What I've done:
    Reseated all components (minus CPU)
    Reseated all cables
    Breadboxed with only CPU in
    Cleared CMOS with pin and battery removal
I'm assuming now that it's a hardware issue. Either the PSU or Mobo is bad. I'm assuming the RAM isn't because the mobo won't POST even with the RAM not installed.
I'm at this point at a loss and I'm waiting for a friend to bring his PC over so I can test some of my parts. Does anyone have any other ideas?
I've already done everything on that list that I can (all except PSU test with testing equipment) and more. I thought that was clear from my post?
CMOS cleared, nothing.
PSU jumped tested, nothing.
All components reseated and cables checked multiple times, nothing.
Memory checked in each DIMM slot. This worked at first, but then nothing.
