Hello,
I have been having an issue with my new install of windows 10 on my 970 EVO 500GB.
The system itself runs like a champ from anywhere between 1-30 minutes before it crashes.
Event viewer just states that the system shut down unexpectedly and that is all.
Bluescreen I was able to catch once indicated a Clock_Watchdog_Timeout error.
I have checked the connections of my SSD and all of my hardware. All seems to be seated correctly on the board. I am worried it could be my M.2 970 EVO.
My system specs are as follows:
Ryzen 7 2700X
16GB DDR4 3000 Ram Trident Z RGB (Name might be wrong)
EVGA 980TI 6GB GPU
970 EVO Samsung 500GB
650W EVGA Modular Power supply.
TUF B450 Plus Gaming Motherboard Asus
I have updated all drivers in system. Followed the M.2 Setup for my MOBO following guides online. Secured my M.2 with screw as instructed and setup windows from boot disk and updated my drivers manually from there. Samsung Magician has been downloaded and firmware is up to date.
Not sure if my MOBO is going bad or what. I look forward to any help I can get. SOS. I would greatly appreciate any wisdom you can impart onto me.
Should also be noted that the PC setup worked prior on my HDD which I still have on standby.
Ryzen 7 2700X
EVGA 980TI 6GB GPU
