from 60 to 5 fps overnight help pls
confirm
17
went from 60 to 5 fps overnight
specs are intel i3-2100 3.10ghz
8gb ram
geforce gtx 560
all with 30's in temp on idle
i installed a windows update and a java program and thats about it .
any help is apriciated :)
Maybe you were stressing out the PSU and it finally had enough of being over stressed and normalized it's self at which point stopped the card from functioning properly.
Either way, for sure upgrade that PSU.
Normally if you are under the correct wattage it simply wouldn't even turn on the display to the monitor.
running furmark and gpu-z still says 0 % gpu load , furmark said 10% memory load.
i have a deltaco psu-430 on 350w
both powerconnectors a firmly in the card
ran registry and ccleaner to no avail too.
dont know if my psu cn be the problem when ive been playing fine for weeks until now ??
looking at the specs for the card now says minimum 450 w on the system, guess im 100 w under it .. how in the hell have i been playing until now if my system didnt meet the req ??
bought a new psu with 600w and waiting for shipment atm.
installed a older card that dosnt need that much power and everything checks out fine.
so guess my psu just had enough lol.
anyway, thanks for the help !! 😀
Looks like you solved this problem overnight! That is good. When I saw the 450W PSU requirement and the fact that your card requires the 2 supplemental 6 pin connections, I thought an underpowered PSU might be the issue. Over time, a PSU will "wear out" and lose the ability to supply the rated power.
I have never heard of a Deltaco PSU. Perhaps it was not that great of a PSU and just wore out.
Did you get a decent PSU? For your rig it doesn't have to be top of the line, but I would suggest at least a Tier 3.
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
