Front audio not working on Lian Li PC-9F
ratsa
425
The front audio ports on my Lian Li PC-9F do not detect that there is anything plugged in.
I even tried at the BIOS stage and the Asrock BIOS system info did not detect that anything was plugged in.
Anyone else experience this problem?
Try moving the audio jumper (FP_Audio on motherboard), it might be set for rear panel only or something. Look up your motherboard and find what all the pins are, there should be 9 pins i think. I had an old motherboard that wouldn't play from the back panel, set pin jumpers correctly and voila, it started working. I didn't understand the whole process that well, why putting a jumper on such and such pins made the difference and why one would set it up that way anyway, but hopefully it at least gives you an idea of what might be the problem. Good luck!
Augray
