Hello Tom's Hardware forum members,
I have a question pertaining to the use of the front audio ports on a computer case when you have a dedicated sound card already installed in the system. I first want to clarify some points that anyone may correct me if I'm wrong. Firstly, when you use a sound card, you have a dedicated card that processes the sound for your system, rather than your CPU. Secondly, decent and higher quality sound cards provide superior sound quality compared to onboard Intel HD audio. Third and lastly, onboard audio is disabled when you use a dedicated sound card. This is the one I'm not too sure about, but it makes sense.
Now with that out of the way, here is the sound card I am interested in purchasing http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006 for a HP Compaq dc5800 small form factor PC. I want this card because it can use a low profile bracket and fit inside my case. I also have the available 4-pin floppy power cable on the PSU that the sound card requires. This sound card also has the audio header so you can connect your front audio ports that are attached to the computer case. The header cable, best illustrated in this PDF http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01362761/c01362761.pdf, that comes from the audio ports on my computer will not reach this sound card without some sort of extension cable. That means I will have to leave the cable plugged directly in the motherboard.
Here finally comes the question I wanted to ask this community. If I install this sound card and were to use the front audio ports on my computer case, would the sound that comes from it be processed by the sound card or the onboard Intel HD audio? This probably poses another question that if the front audio ports would even work since they go to the motherboard, rather than directly to the sound card. I'm guessing they still would and the sound may be processed by the dedicated sound card and then just channeled through the motherboard to bring me the crisp sound I payed money to produce. Any geniune input would be helpful from the community on this forum
P.S. I'm sorry that I posted the URLs in this manner, but I was having trouble using the URL entry tool on this forum on both links.
Thanks,
Junkyard Dawg
Thanks,
Junkyard Dawg
