So I bought the Kraken x62 and the only place to mount it is at the front, my question is, as I'm replacing 2 fans on the front which would usually be running on full speed, do I keep the radiator fans on full speed? Because again, as I'm replacing 2 fans that would normally run on full anyway, it won't add much noise. Also, I've always ran my current pump at full, but I hear the x62 has variable speeds? So, do you think I should keep intake fans at full and just let the pump speed up/slow down according to temperatures? Thanks!
