J jackroden64 May 29, 2018 1 0 10 May 29, 2018 #1 Would buying a new pc case fix audio jack problems?
Solution helpstar May 29, 2018 if the front jacks are broken, than yes, a new case or front panel would help http://www.dx.com/p/zap-usb-2-0-usb-3-0-hd-audio-chassis-optical-drive-front-panel-black-337781
BringerOfTea Reputable Dec 17, 2015 1,485 61 5,740 May 29, 2018 #2 The front panel audio jack is often prone to interference, what are your problems to be specific? Doubt that changing case would make a difference Upvote 0 Downvote
helpstar Titan Dec 25, 2012 13,266 777 83,840 May 29, 2018 Solution #3 if the front jacks are broken, than yes, a new case or front panel would help http://www.dx.com/p/zap-usb-2-0-usb-3-0-hd-audio-chassis-optical-drive-front-panel-black-337781 Upvote 0 Downvote Solution
