[SOLVED] Front panel cabels dont seem to go in motherboard! HELP!!
romethaug28
112
I am building my first PC. My motherboard is Lenovo m91p Thinkcentre on (link: https://www.amazon.com/Lenovo-Thinkcentre-M91p-Motherboard-03T8351/dp/B078XGTYLY).
The motherboard´s audio slot says F_audio and the cabel says audio. They arent similar at all. The usb slots are left over with one line of pins (2 pins). And the single cabels like: Power Swich, Reset swich, Power led etc), i cant find place for those either. or there are just too much pin places left over. Am i screwed over?
All help is welcomed!
Thank you!
Thank you!
thats the way you conect the front panel https://drive.google.com/file/d/1OUlTC2b7Etjf7CyUOd5F4Bjbd9zoEyAA/view?usp=sharing
hmm, i took a look. it tells that what are these things for, i get it. But it doesnt tell me what to put where. Also the usb slots and audio slot arent the exact same as the mobo´s. Well thank you anyways!
Thank you!
