I am having problems connecting my front panel header to the motherboard.
The problem is, I am using an old chassis with this type of connector and a motherboard with this header:
The problem is, the chassis connector is 1 solid block connection, like a USB 2.0 or Audio header connector instead of a bunch of single wires.
So my problem is that when I plug in the chassis connector, the 9th pin overlaps with the chassis intrusion (-) pin on the mobo.
The machine seems to boot fine with the power button, but every time I try to turn the power off it restarts itself.
Is there something I'm missing? I've never seen a single block front panel connector and I'm not sure how to proceed.
Thanks for any advice on the subject.
![fmnNWxT3.png](/proxy.php?image=https%3A%2F%2Fi.imgbox.com%2FfmnNWxT3.png&hash=b2828e619718d24d02b99f047f87f261)
