I recently built a new rig, and am having difficulty with the front panel audio jacks. The headphone and microphone jacks always indicate that a device is inserted, even if there is no device. The rear panel works fine, properly detecting when a device is inserted/removed. What's more, devices inserted into and removed from the front panel jacks are detected while in the UEFI setup. This seems to indicate it's a software issue.
This isn't terrible, but I'd rather not have to disable/enable or change the default device every time I switch between my speakers plugged into the rear jack and headphones plugged into the front jack, which I do quite frequently. I'm also just curious as to what the issue is.
The motherboard is an ASRock z77 Extreme4 and the case is an Antec P280, and the HD Audio connector is firmly and properly seated. I've tried the latest Realtek driver found from the motherboard manufacturer as well as the latest version from the Realtek website, and have also tried just using the drivers automatically provided by Microsoft. No dice with anything.
Anyone have any ideas? Thanks in advance![Smile :) :)](/data/assets/smilies/smile.gif)
