So you are concerned if an led connector is damaged? From what's written, all I see is the pin has twisted inside the connector. That's a non issue.
If you twisted the motherboard pin and it now spins, that's a different issue, but regardless it's just power to the led in the button that tells you if the pc is on or not. Hmm. If you can't tell if the pc is on or not without the led, you have bigger issues. 👍😁
