I am planning to buy a front panel hub with 4x USB 3.0 slots that uses a USB 3 motherboard header. I read somewhere that the USB 3 header only supports 2 USB 3.0 connection, so basically the other two USB 3.0 ports on the front panel will be useless? BUT the hub also has two USB 3.0 male cables which, I think, run through the case, out the back, and into 2 USB 3.0 motherboard slots. So you're pretty much just stealing two usb slots form the back and using them for the front.
A few questions:
Whenever I see a front panel hub with more than 2 USB 3.0 slots, the other slots are pretty much useless?
Do the SD card slots on the hub connect through USB 3.0 speeds since its using the USB 3.0 motherboard header?
If I get a front panel hub with 4x USB 3.0 that uses a PCI E connector instead of a USB 3 header, will I be limited in speed if I was, for example, using two of the USB 3 slots. I read somewhere that the maximum TOTAL bandwidth is 133 MB/s on the PCI E, whereas the USB 3 header supports both USB slots for their whole 640 MB/s?
Sorry in advance if I messed up any connection concepts. Thanks
A few questions:
