FS: 20x Bitspower 1/4 Thread Compression Fitting for Water Cooling
cyrus104
I bought a bunch of these for a build and then decided to go a different way. I have other water cooling parts as well. I'm in the DC area and can ship these out asap. I only accept Paypal.
Will sell the lot for $150, if you look them up on other sites they are worth more. None of the parts have ever been used.
http://i1292.photobucket.com/albums/b574/cyrus104/IMAG0234_zps0805cd16.jpg
Description:
Special Design for PC Water Cooling
Perfect Surface treatment
TRUE Hi-Flow
Hidden O-Ring Design
Compression Fitting Designed For ID 7/16" (11MM) with OD 5/8" (15.875MM)
Specifications:
Material : Hi Quality Brass with Black Sparkle coating
Thread : G1/4"
Tubing Size : ID 7/16" With OD 5/8" (thin wall PVC type tubing)
