[SOLVED] FS XGSPON SFP+ Module Setup with UniFi Pro Max ?
Cemil2565
18
Dear Networking Experts,
I am seeking advice on configuring a 10G XGSPON SFP+ module from FS.com to replace my Nokia ONT and connect it directly to my UniFi Pro Max. ISP is Proximus
Issue Details:​
  • XGSPON Serial Number: I’ve located the correct GPON serial number and entered it into my ISP’s "Install Your Own Equipment" portal. My old Nokia ONT was disabled successfully, but I am still not receiving Ethernet from the SFP module. Even tho Unifi sees the Module connected (picture)
  • Possible Cloning Requirements: It may require additional details from the Nokia ONT, such as cloning certain settings (e.g., serial number, MAC address, or other identifiers) onto the SFP module or not idk.
Questions:​
  1. UniFi Configuration: Are there any specific settings I need to apply on the UniFi Pro Max for XGSPON SFP+ compatibility?
  2. Cloning ONT Details: Has anyone successfully cloned a Nokia ONT’s configuration (serial number, MAC address, etc.) to an SFP module for ISP activation? If so, what tools or commands were used? and do i need that is that my problem?
  3. Telnet or Console Access: Should I access the SFP+ module via Telnet to confirm or modify its settings for ISP requirements? (FS customer support said dont change Gpon id or password.)
  4. Also i can only Telnet the sfp module only when its in lan port, when i change its port again to wan from unifi, i cant access telnet, it needs to be in lan mode, thats normal right?
Current Setup:​
  • ISP: Belgium-based Fiber ISP
  • Device: UniFi Pro Max
  • Module: FS.com10G GPON SFP+
Any guidance on how to proceed with cloning or configuring the module to ensure full compatibility with the ISP would be greatly appreciated.
Thank you for your help!
Latest posts
