Question Fujitsu laptop hibernates itself when battery reaches 20% ?
Jan 26, 2024
Hello guys!
I have a Fujitsu Lifebook E753 laptop and I have a problem that when the battery reaches 20%, Windows hibernates itself. I couldn't find any settings for this in the bios, in Windows the power plan is set to Performance.
Can anyone help me how to turn off this hibernation or setting?
Laptop specification:
i5-3320m, 8gb ddr3, 2x 250Gb SSD, intel hd 4000, Windows 7 Ultimate
Go into your windows power plan (Search "Edit Power Plan" in Windows Search) and click the Battery Drop-down. There should be "Low Battery level" and "Critical Battery Level" along with their respective "Action" drop-downs. Just see which one is set to act at 20% and change its setting from "hibernation -> Do nothing".
I checked now, but it won't let me set it to "do nothing". There is sleep, hibernation, and shutdown.
And for some reason, it won't allow you to set it below 17% at critical charge.
