G
Guest
Guest
Archived from groups: rec.audio.pro (More info?)
Kayte wrote:
> > Why not just hook the mics up to the recorder directly?
> Why not indeed. I disagree with the wireless setup, I think it will
> complicate things, introduce noise, and be much more likely to fail.
> If you have more info to help me demonstrate this point I would most
> appreciate it.
I seem to remember some reference to the Library of Congress earlier on
in this thread, that the LofC guidance was what was driving this
further and further into nonsense. You're doing oral history. The best
thing your collectors can do is be aware of the acoustic environment
and control it to the extent feasable if it's bad enough to affect the
reoording. The best mic preamp in the world won't improve a recording
made with a TV blasting in the next room or the neighbor running his
lawnmower.
I've done some work with the LC Folklife Center and in their "Field
School" they emphasize reliability and common sense over technology.
Their standard rig is a Marantz portable cassette recorder and rugged
dynamic mics.
> appreciate it.
lawnmower.
dynamic mics.
