Okay, I have an oem fx-6200 in my new build. Problem is, after about 5 mins of skyrim(on ultra) the cpu temp goes up to 75 or so, and gpu(hd7770) hits over 50. I have an arctic a30 heatsink/fan on my cpu, so does it seem likely that I need to reseat the cooling on my cpu? I have three fans in the case, not counting the built-in fans on the gpu and spu.
I did have trouble installing the a30 heat sink, as the way the fan is situated leaves no room to screw in the heatsink/mount screw on the fan side, so I had to use my fingers. I'm thinking that may be the problem, but no idea how to fix it. Any ideas?
