fx 6300 and msi gtx960 2g but low fps on dota 2 reborn 30-40 pls help
badfps666
hey i have a problem with my cpu right now
i just upgraded my graphic card from hd7850 to gtx960 to solve my fps problem but after that i still got the same fps,, im playing dota 2 reborn but still got 30-40fps just same as my hd7850 performance, is there any problem with my pc's spec ? because i saw a benchmark test on youtube about gtx960 it said it will run 60fps on dota 2 if i use this gtx960 but it didnt work at all
here's my spec:
Processor AMD FX 6300 Vishera 6 Core 3,5Ghz
Motherboard Asrock 970 Pro 3 AMD+
RAM Kingston HyperX Fury Red 2x4GB
VGA MSI gtx960 2g
Monitor Dell P2214H IPS 22"
PSU Corsair CX500
pls help guys 🙁
1) Overclock your 6300 if possible. 4.3-4.5 is a safe bet.
2) Update to latest GPU drivers
3) Make a profile for Dota 2 in Nvidia Control Panel.
4) Enable Power to High Performance, Shader Cache to On and Multithreading to On
5) If you are CPU bound (I doubt it), consider using DSR to play the game at resolutions above your native monitor resolution to make the game GPU limited for better performance AND visuals.
6) Set your PC to high performance, so the CPU doesn't underclock
7) Check for Core Parking issues once you start the game, EVERYTIME you start the game. The game itself, not for each match.
Uncheck Vertical Sync if you ticked it. If your CPU is running at stock speeds, then a lil OC'ing up to 3.8 should be enough. Make sure to remove every trace of your old drivers using DDU and re-install nvidia's drivers fresh.
