Specs:
FX 6300
HD 7750 XFX
4Gb RAM
I was monitoring my CPU temps and GPU because, on easy to run games, i get fps drop quite frequently, when my system should be enough to run these games in max (for instance, Ghosts recon Phantoms) i know that these things aren't accurate at all, but the heat spikes that i got readings of, happen when my game starts to slow down...to be more exact Speedfan detected a Max temp of 255ºC on the CPU when i got the fps drop, i know this is practically impossible, i don't smell anything funny and my case hasn't burst on fire, i read a couple of threads about this and it says that i should update my BIOS...but to be honest i am afraid of that, also my PC is kind of dirty i plan on using compressed air to clean it tomorrow and see if i can get this fixed because it is really annoying...anything else i can do? any ideas? please help if you can :c
EDIT=It was actually Core Temp, not Speedfan 😛
FX 6300
HD 7750 XFX
4Gb RAM
