fx 8320 clock speed drop
Jul 2, 2018
23
hey can i ask you guys something
. when i run prime95 test cpu multiplier drop x7 from x19 in 2 minutes. When the temperature of the processor is 67 degrees and the core temperature is 60 degrees, the multiplier drops. i disable all power saving options (c1e,cool 'n quiet,c6 state vs) but i keeps going down every 2 minutes. i changed thermal paste yesterday.
so, how can i disable cpu's heat protection. more warming does not matter for me just it keep runing to x19
sorry for bad english 🙁
amd says it will be work at 80 degrees. It will not be a problem at 70 but it starting to fall 65 degrees. its annoying fps drops with it. thanks for quick reply
i'm checking with cpu-z,core temp and aida64 extreme they are all says core temp is 59-60 degrees. core temp's max heat says 80 degrees is it's max temp. I think it's a general information for all cpu's not special for mine
MSI 970a g-43
This is a similar board to yours, with a similar CPU.
https://www.youtube.com/watch?v=8zTzpYjQ2MM
DO NOT turn off the protections. In fact your board has very poor quality 4+1 VRMs, you need some cooling over them for it to be normally stable.
The msi g43 & g46 purposefully force a false temp reading to throttle the cpu's if the vrm's come unde too much stress.
With an 8 core chip that happens under 80%+ loads constantly.
You should re-enable cool & quiet for starters, disabling it is running your cpu hotter & with more voltage at low loads for absolutely nothing.
Investing ANY money in that platform is a waste. Save up your money a bit and get a Ryzen 3 and motherboard and ram, it will demolish that 8320 in everything.
