FX-8320 Low clocks
Zouha
6
I have default settings on my fx-8320, 3,5GHz and 4,0GHz turbo clock. However, when I play games or run stress tests, the clock never goes to 4,0GHz, but stays at 3,5GHz or 3,7GHz. The cpu utilization stays low as well. I'd like to get as much power out of my cpu so I could play cpu intensive games at higher framerates.
Have you tried turning all the power saving options off in bios, particularly the one that controls clock speeds? If you disable it and it shows the correct speeds, then it may be restricting how much it clocks up to. I would guess it could also be throttling for some reason (Possibly heat?) though I'm not too informed on CPU throttling.
My setup:
CPU: fx-8320
GPU: gtx 760
Mobo: Asus m5a99x evo r2.0
cpu cooler: CM Hyper 212 Evo
some 550W Psu I think?
Socket temp is around 55 C and core temp something like 45C when playing games like gta V.
