FX 8350 fan working way too slow, temps get too high.
yaka95
Commendable
Jun 3, 2016
So yesterday I upgraded to Win10 from 8.1 and once finished I did a reset to get a fresh start. After that I updated my video drivers because it has been a while.
Note: I didn't have to install all the drivers after the reset, windows remembered them for me (at least thats what I think because the video driver was there once the reset finished).
Anyway, later today I start downloading Battlefield 3 from Origin and the CPU temp went to 80°C and the computer overheated and shut down. Later I tried playing CS:GO and I was almost reaching 80°C again, where usually I would get 50-60°C. It feels like the CPU fan is not working as hard, as in the temps are extremely high yet the fan is really quiet.
I have been using this PC for over 2 years and never had heat problems. Funnily enough my idle temps are extremely low at >20°C which I didn't really get before.
Here are my specs:
FX 8350 (stock cooler)
HD 7970
ASUS Crosshair V Formula Z
Corsair CX750M
8 GB RAM @ 1600
ps: I changed the power options on windows to "high performance" from "balanced" which was default, but on Win8.1 I always had it at "high performance".
Thanks
Here are the best coolers out there
Corsiar Hi00 V2 (water) :http://www.amazon.com/dp/B019EXSSBG/?tag=pcpapi-20
Cooler Master Hyper 212 EVO ( Air ) : http://www.amazon.com/dp/B005O65JXI/?tag=pcpapi-20
The 212 EVO is only...
Speedy Mcool
91
So I just bought the 8350. And even on the reviews of the Fx 8350 people were saying that the fan was horrible, loud, and not effective. Instead of going though any pain I ordered a Corsair Hi00 V2. Works perfectly with the processor and very little noise. The problem could just be your processor decided to die on you or your fan did.
yaka95
Commendable
Jun 3, 2016
Could be that the fan died on me recently and I hadn't noticed because I haven't used my computer much in the past 2 weeks. I'll look into getting an aftermarket cooler.
Speedy Mcool
91
The 212 EVO is only 29 dollars, so thats a great option
yaka95
Commendable
Jun 3, 2016
Thanks for the tip :D
Speedy Mcool
91
Anytime!
