FX 8350 Heatsink not compatible with mobo?
nugget827
Commendable
Nov 28, 2016
12
Hi. I am new to the cpu world and I am trying to install a heatsink for my new FX-8350 onto my Gigabyte GA-970A, but it appears I do not have a mount on which to install the heatsink. There are also 4 holes for screws around the processor which I assume is where the mount would go. If anyone knows, how would I find a mount to buy? Thanks
I am using the heatsink that came with the fx8350.
I forgot to mention that when I first got my pc it was a prebuilt with liquid cooling so there is no mount at all.
AM3+ has the mounting solution built right in, and hasn't changed in ages. It should look like this:
http://thumbs2.ebaystatic.com/d/l225/m/mMWxuvNAaXm2gRWZ-IpjrYw.jpg
Your water cooler may have had a different mounting solution, but i really don't think so.
The cooler should just clip on using the edges you can see in the top portion.
