[SOLVED] FX 8350 Stock Cooler Noise
guymarshall
549
4
11,015
I have a corsair h100i and it is stupidly loud even at idle with perfect temperatures of around 20 degrees. I was wondering, is the fx 8350 stock cooler really as loud as people say it is? I enjoyed my a10 6700 stock cooler, it was quiet even when overclocked. I don't know if people are just over exaggerating the noise. I will not be overclocking the 8350, I will be running it at clock speeds like 1-1.4 GHz.
I think the fans and pump are faulty, they are at 2400 rpm at idle and scream all the time. Is the fx 8350 cooler really louder than the a10 6700 cooler? You would think that a higher end cooler would be quieter.
GPUs are excellent at parallelism, so they can easily outperform a CPU, which is why some high end graphics cards are built with 3 fans, huge heatsinks and huge copper pipes. CPUs can have that if they are overclocked, but usually they don't because they don't produce as much heat.
The processor still has to supply the information to the graphics card to process, which is why you cant pair a high end graphics card with a budget graphics card. The processor wont be able to keep up, and will limit what the graphics card can do.
The cooling on the GPU has exactly nothing to do with this fundamental relationship.
I got a bit confused when I was explaining haha. The CPU at 1GHz does more than 1 billion FLOPS, and so even if the graphics card has to turn down it's own speed slightly it won't make a difference. Also there are 8 cores on my CPU, not all will be used but it is enough to game on.
Do you have software that monitors your fan speed (e.g. Corsair Link)? You need to set a fan profile so it slows the RPM when idle, speeds up when under load.
I don't know why you would underclock your CPU to be honest, but that's your choice.
