Info G Hub replaced LGS
Colif
Win 11 Master
So if you use a Logitech device, you may be able to swap from using Logitech Gaming Software over to G Hub - it can save the settings you already have and allow you to avoid re creating them. Sure saved time on my G910
https://www.logitechg.com/en-us/innovation/g-hub.html
This isn't really a sales pitch. Its more a warning as if you install it, it doesn't automatically uninstall LGS. It leaves it running and if you don't notice, can cause problems as you may have 2 bits of software running kb, for instance. May cause slowdown.
So if you install it, make sure to uninstall LGS after running G Hub the first time (this lets it copy color schemes and key settings)
Make sure your device is compatible with the service before swapping
