I recently built a new PC after my old HP died. These are the parts:
Gigabyte Z97X Gaming 5
Intel Core i7 4790K
G.SKILL Trident X Series 16GB (2 x 8GB) DDR3 2400 CL10 1.65V
ASUS GTX660-DC2O-2GD5
EVGA SuperNOVA 850 B2
Cooler Master Hyper 212 EVO
StarTech PCIe Wireless Adapter
5x120mm case fan, 1x230mm case fan
So I put the whole thing together, and went to boot up for the first time and it didn't POST. My monitor stayed blank and my mobo speaker gave continuous short beeps with a power cycle. I found this meant a power error. However this seems to be false. I managed to isolate (at least I hope/think so) the issue to the RAM.
Something about the RAM is causing the problem. I'm fairly certain the RAM sticks themselves are fine. My RAM slots are labelled as follows:
CPU
DIMM 4 (Black)
DIMM 2 (Grey)
DIMM 3 (Black)
DIMM 1 (Grey)
I have tested both sticks one at a time in slots 1 and 3 and that POSTs fine but 2 and 4 individually (i guess that makes sense since 1 or 3 should be filled first) and the 1,2 and 3,4 pairs don't POST, giving me the blank screen and short continuous beeps with power cycle.
I tried turning on XMP and it seems to have autodetected the stick specs.
I have changed DRAM voltage to 1.66V (it goes up by increments of 0.02V).
I have also tried loosening the cpu cooler and tightening it again screw tight.
I have now installed Windows with just the one stick and wondering if i should update the BIOS?
How do I get the 2 sticks to work together? Doesn't make sense why the dual channel setup doesn't work.
Intel Core i7 4790K
CPU
DIMM 4 (Black)
DIMM 2 (Grey)
DIMM 3 (Black)
DIMM 1 (Grey)
