Question G41M-VS3 motherboard not letting ram run in 1333 speed
Jun 27, 2019
In the bios settings, I cant set the ram to run at 1333. I have tried multiple things but I'm not sure how to configure the bios or if it's even possible, the website of the motherboard says that I can run DDR3 ram at 1333 but I can't seem to find how.
https://www.asrock.com/mb/intel/g41m-vs3/
CPU-Z TXT Report
Binaries
CPU-Z version 1.89.1.x64
Processors
Number of sockets 1
Number of threads 2
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 1)
-- Thread 1 1
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Core 2 Duo E7500
Codename Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
TDP Limit 65.0 Watts
Core Speed 2926.0 MHz
Multiplier x Bus Speed 11.0 x 266.0 MHz
Base frequency (cores) 266.0 MHz
Base frequency (ext.) 266.0 MHz
Rated Bus speed 1064.0 MHz
Stock frequency 2933 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
Microcode Revision 0xA0C
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 3072 KBytes, 12-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 3 MB, 2 thread(s)
FID/VID Control yes
FID range 6.0x - 11.0x
Max VID 1.275 V
Temperature 0 94 degC (201 degF) (Core #0)
Temperature 1 82 degC (179 degF) (Core #1)
Clock Speed 0 2925.96 MHz (Core #0)
Clock Speed 1 1595.98 MHz (Core #1)
Core 0 max ratio (effective) 11.0
Core 1 max ratio (effective) 11.0
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x0001067A 0x00020800 0x0C08E3BD 0xBFEBFBFF
0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB43048
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x04000121 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04004143 0x02C0003F 0x00000FFF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x00022220
0x00000006 0x00000001 0x00000002 0x00000003 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000400 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000003 0x00000240 0x00000240 0x00000000
0x0000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x44203229 0x43206F75 0x20205550 0x45202020
0x80000004 0x30303537 0x20402020 0x33392E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x0C006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x00000017 0x04000000 0xA9848B24
MSR 0x0000003F 0x00000000 0x00000000
MSR 0x000000CE 0x00160B24 0x46460712
MSR 0x000001A0 0x00000040 0x6A972489
MSR 0x000000EE 0x00000000 0x86790300
MSR 0x0000011E 0x00000000 0xBE702119
MSR 0x000000CD 0x00000000 0x80000800
MSR 0x0000019C 0x00000000 0x88000003
MSR 0x00000198 0x06160B24 0x06360624
MSR 0x00000199 0x00000000 0x00000B24
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x0001067A 0x01020800 0x0C08E3BD 0xBFEBFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x0000019C 0x00000000 0x88070000
MSR 0x00000198 0x06160B24 0x060C0616
BIOS
UEFI No
Chipset
Northbridge Intel G41 rev. A3
Southbridge Intel 82801GB (ICH7/R) rev. A1
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 8 GBytes
Channels Dual, (Symmetric)
Memory Frequency 532.0 MHz (1:2)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Row Refresh Cycle Time (tRFC) 78
Command Rate (CR) 2T
Host Bridge 0x2E30
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Module Manufacturer(ID) Patriot Memory (7F7F7F7F7F020000000000)
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number PSD34G13332
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP no
AMP no
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00
10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 01
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 85 02 02 00 00 00 00 00 00 FD BA
80 50 53 44 33 34 47 31 33 33 33 32 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
Monitoring
Mainboard Model G41M-VS3. (0x00000230 - 0x0277AAE8)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83627DHG-P
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xB0
LPCIO Revision ID 0x73
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 B0 73 FF 00 44 00 00 FF 70 00 00 00 D2 21 00 FF
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Winbond W83627DHG
Voltage 0 1.12 Volts [0x8C] (CPU VCORE)
Voltage 1 0.96 Volts [0x78] (VIN1)
Voltage 2 3.06 Volts [0xBF] (+3.3V)
Voltage 3 4.58 Volts [0xBF] (+5V)
Voltage 4 10.65 Volts [0xBF] (+12V)
Voltage 5 1.71 Volts [0xD6] (VIN5)
Voltage 6 1.85 Volts [0xE7] (VIN6)
Temperature 0 39 degC (102 degF) [0x27] (SYSTIN)
Temperature 1 71 degC (158 degF) [0x8D] (CPUTIN)
Temperature 2 52 degC (124 degF) [0x67] (AUXTIN)
Fan 1 2344 RPM [0x48] (CPUFANIN0)
Hardware registers
bank 0
00 04 FF 04 FF 01 00 32 20 01 80 01 01 3C 3C 0A 0A
10 04 FF 10 00 00 01 01 3C 43 07 00 00 2C FF FF D0
20 8E 78 BF BF BE D6 E5 27 FF 49 FF DA 00 BC B9 6E
30 B5 B5 CA FF C4 95 56 39 43 5B 2E D8 4F 95 3D FF
40 03 6E 1F FF FF 00 3F F5 2D 00 00 C4 10 95 00 A3
50 FF FF 00 FF FF FF 00 80 C1 7F FF FF 19 A0 00 05
60 04 7F 40 00 01 01 3C FF 01 FF 01 FF FF FF FF 00
70 00 00 00 00 00 0E 7F 7F 7F 7F 7F 7F 00 27 FF FF
80 04 FF 04 FF 01 00 32 20 01 80 01 01 3C 3C 0A 0A
90 04 FF 10 00 00 01 01 3C 43 07 00 00 2C FF FF D0
A0 8E 78 BF BF BE D6 E5 27 FF 49 FF DA 00 BC B9 6E
B0 B5 B5 CA FF C4 95 56 39 43 5B 2E D8 4F 95 3D FF
C0 03 00 10 FF FF 00 3F F5 2D 00 00 C4 10 95 00 A3
D0 FF FF 00 FF FF FF 00 80 C1 7F FF FF 19 A0 00 05
E0 04 7F 40 00 01 01 3C FF 01 FF 01 FF FF FF FF 00
F0 00 00 00 00 00 0E 7F 7F 7F 7F 7F 7F 00 27 FF FF
bank 1
50 46 80 00 4B 00 50 00 EC 00 00 00 00 00 00 0E FF
bank 2
50 34 00 00 4B 00 50 1F 1A FF FF FF FF FF FF FF FF
bank 3
50 05 05 00 03 07 00 01 06 00 00 00 E0 32 01 00 00
bank 4
50 3B 13 FF 00 00 00 00 01 30 4E 1D BB 09 5F 20 7F
Hardware monitor D3D
Hardware monitor AMD ADL
Voltage 0 1.00 Volts [0x3E8] (GPU)
Temperature 0 56 degC (132 degF) [0x38] (GPU)
Clock Speed 0 300.00 MHz [0x12C] (Graphics)
Clock Speed 1 533.00 MHz [0x215] (Memory)
Clock Speed 2 n.a. (Processor)
PCI Devices
Register space PCI Express, base address = 0x0F0000000
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2E30
Revision ID 0x03
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1849
Subsystem ID 0x2E30
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Vendor Dependant
Caps offset 0xE0
PCI registers
00 86 80 30 2E 06 00 90 20 03 00 00 06 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 30 2E
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 01 90 D1 FE 00 00 00 00 01 40 D1 FE 00 00 00 00
50 00 00 02 00 03 00 00 00 00 00 00 00 00 00 00 00
60 05 00 00 F0 00 00 00 00 01 80 D1 FE 00 00 00 00
70 00 00 00 00 00 00 00 00 01 08 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 10 11 11 00 00 33 33 00 80 00 88 00 00 1A 38 00
A0 80 00 40 22 00 00 00 DC 00 00 00 DC 00 00 00 DC
B0 00 DC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 03 03 00 00 60 66 66 13 00 00 00 D2
E0 09 00 0C 61 24 0B A7 CF E2 9D 2F 81 00 00 00 00
F0 00 00 00 00 08 00 00 00 A6 0F 05 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2E31
Revision ID 0x03
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps class Subsystem Vendor
Caps offset 0x88
SubVendor ID 0x1849
SubSystem ID 0x2E31
PCI capability
Caps class Power Management
Caps offset 0x80
Caps version 1.2
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x90
PCI capability
Caps class PCI Express
Caps offset 0xA0
Device type Root Port of PCI-E Root Complex
Port 2
Version 2.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
Extended capabilities
Caps class Virtual Channel
Caps offset 0x100
Caps class Root Complex Link Declaration
Caps offset 0x140
Link Entries # 1
Port Number 2
PCI registers
00 86 80 31 2E 07 05 10 00 03 00 04 06 08 00 01 00
10 00 00 00 00 00 00 00 00 00 04 04 00 E0 E0 00 20
20 B0 FE B0 FE 01 E0 F1 EF 00 00 00 00 00 00 00 00
30 00 00 00 00 88 00 00 00 00 00 00 00 0B 01 1A 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
80 01 90 03 C8 08 00 00 00 0D 80 00 00 49 18 31 2E
90 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 10 00 42 01 00 80 00 00 00 00 00 00 01 25 21 02
B0 40 00 01 51 80 25 00 00 00 00 48 00 00 00 00 00
D0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 01 00 03 41 3F 80 90 0F 05 00 00 F0 00 F0
100 02 00 01 14 00 00 00 00 00 00 00 00 00 00 00 00
110 01 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x27D8
Revision ID 0x01
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE9FC000
Subvendor ID 0x1849
Subsystem ID 0x0397
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x70
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
Caps offset 0x100
Caps offset 0x130
Link Entries # 1
Port Number 15
PCI registers
00 86 80 D8 27 06 00 10 00 01 00 03 04 08 00 00 00
10 04 C0 9F FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 97 03
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
40 01 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 00 00 08 10 00 00 00 00 00
C0 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 86 0F 01 00 00 00 00 00
100 02 00 01 13 01 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
130 05 00 01 00 00 01 00 0F 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x27D0
Revision ID 0x01
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps offset 0x40
Port 1
Version 1.0
Physical slot #0
Presence detect no
Link width 0x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1849
SubSystem ID 0x27D0
PCI capability
Caps offset 0xA0
Caps version 1.1
Caps offset 0x100
Caps offset 0x180
Link Entries # 1
Port Number 1
PCI registers
00 86 80 D0 27 06 05 10 00 01 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 02 02 00 F0 00 00 20
20 F0 FF 00 00 F1 DF F1 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 0B 01 06 00
40 10 80 41 01 C0 0F 00 00 00 00 10 00 11 4C 11 01
50 00 00 01 10 60 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0D A0 00 00 49 18 D0 27 00 00 00 00 00 00 00 00
A0 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 11 00 00 00 00 00
E0 00 00 C7 00 06 07 08 00 00 00 00 00 00 00 00 00
100 02 00 01 18 01 00 00 00 01 00 00 00 00 00 00 00
110 01 00 00 00 01 00 00 80 00 00 00 00 01 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x27D2
Revision ID 0x01
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x0A
Int. Pin 0x02
PCI capability
Caps offset 0x40
Port 2
Version 1.0
Physical slot #0
Presence detect no
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1849
SubSystem ID 0x27D2
PCI capability
Caps offset 0xA0
Caps version 1.1
Caps offset 0x100
Caps offset 0x180
Link Entries # 1
Port Number 2
PCI registers
00 86 80 D2 27 06 05 10 00 01 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 20
20 F0 FF 00 00 E1 DF E1 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 0A 02 06 00
40 10 80 41 01 C0 0F 00 00 00 00 10 00 11 4C 11 02
90 0D A0 00 00 49 18 D2 27 00 00 00 00 00 00 00 00
Description USB Controller (UHCI)
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x27C8
Revision ID 0x01
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000C480
Subvendor ID 0x1849
Subsystem ID 0x27C8
Int. Line 0x17
Int. Pin 0x01
PCI registers
00 86 80 C8 27 05 00 80 02 01 00 03 0C 00 00 80 00
20 81 C4 00 00 00 00 00 00 00 00 00 00 49 18 C8 27
30 00 00 00 00 00 00 00 00 00 00 00 00 17 01 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 20 00 00 00 00 00 00 00 00 01 00 00 00 00 00
Location bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x27C9
Revision ID 0x01
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000C800
Subvendor ID 0x1849
Subsystem ID 0x27C9
Int. Line 0x13
Int. Pin 0x02
PCI registers
00 86 80 C9 27 05 00 80 02 01 00 03 0C 00 00 00 00
20 01 C8 00 00 00 00 00 00 00 00 00 00 49 18 C9 27
30 00 00 00 00 00 00 00 00 00 00 00 00 13 02 00 00
Location bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x27CA
Revision ID 0x01
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000C880
Subvendor ID 0x1849
Subsystem ID 0x27CA
Int. Line 0x12
Int. Pin 0x03
PCI registers
00 86 80 CA 27 05 00 80 02 01 00 03 0C 00 00 00 00
20 81 C8 00 00 00 00 00 00 00 00 00 00 49 18 CA 27
30 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
Location bus 0 (0x00), device 29 (0x1D), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x27CB
Revision ID 0x01
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000CC00
Subvendor ID 0x1849
Subsystem ID 0x27CB
Int. Line 0x10
Int. Pin 0x04
PCI registers
00 86 80 CB 27 05 00 80 02 01 00 03 0C 00 00 00 00
20 01 CC 00 00 00 00 00 00 00 00 00 00 49 18 CB 27
30 00 00 00 00 00 00 00 00 00 00 00 00 10 04 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x27CC
Revision ID 0x01
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE9FBC00
Subvendor ID 0x1849
Subsystem ID 0x27CC
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0x58
PCI registers
00 86 80 CC 27 06 00 90 02 01 20 03 0C 00 00 00 00
10 00 BC 9F FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 CC 27
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
50 01 58 C2 C9 00 00 00 00 0A 00 A0 20 00 00 00 00
60 20 20 FF 01 00 00 00 00 01 00 00 00 00 20 00 C0
70 00 00 DF 3F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 AA FF 00 FF 00 FF 00 20 00 00 88
E0 00 00 00 00 DB B6 6D 00 00 00 00 00 00 00 00 00
F0 00 80 00 09 88 85 40 00 86 0F 01 00 0A 17 02 20
Location bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xE1
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps offset 0x50
SubVendor ID 0x1849
SubSystem ID 0x244E
PCI registers
00 86 80 4E 24 07 01 10 00 E1 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 20 D0 D0 80 A2
20 A0 FE A0 FE F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 06 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
50 0D 00 00 00 49 18 4E 24 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x27B8
Revision ID 0x01
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1849
Subsystem ID 0x27B8
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xE0
PCI registers
00 86 80 B8 27 07 00 10 02 01 00 01 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 49 18 B8 27
40 01 08 00 00 80 00 00 00 81 04 00 00 10 00 00 00
60 8B 8A 86 85 D0 00 00 00 80 80 80 83 00 00 00 00
80 00 00 0F 14 81 02 FC 00 00 00 00 00 00 00 00 00
A0 20 06 00 00 39 00 00 00 13 00 00 00 00 03 10 00
B0 00 00 F0 00 00 00 00 00 00 00 00 08 00 00 00 00
D0 33 22 11 00 67 45 00 00 C0 C0 00 00 00 00 00 00
E0 09 00 0C 10 A8 00 24 00 00 00 00 00 00 00 00 00
F0 01 C0 D1 FE 00 00 00 00 86 0F 01 00 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 31 (0x1F), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x27DF
Revision ID 0x01
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FFA0
Subvendor ID 0x1849
Subsystem ID 0x27DF
Int. Line 0x00
Int. Pin 0x01
PCI registers
00 86 80 DF 27 05 00 88 02 01 8A 01 01 00 00 00 00
10 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
20 A1 FF 00 00 00 00 00 00 00 00 00 00 49 18 DF 27
30 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00
40 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x27C0
Revision ID 0x01
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000C400
Address 1 (port) 0x0000C080
Address 2 (port) 0x0000C000
Address 3 (port) 0x0000BC00
Address 4 (port) 0x0000B880
Subvendor ID 0x1849
Subsystem ID 0x27C0
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps offset 0x70
Caps version 1.1
PCI registers
00 86 80 C0 27 05 00 B0 02 01 8F 01 01 00 00 00 00
10 01 C4 00 00 81 C0 00 00 01 C0 00 00 01 BC 00 00
20 81 B8 00 00 00 00 00 00 00 00 00 00 49 18 C0 27
30 00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
40 07 A3 00 80 00 00 00 00 01 00 01 00 00 00 00 00
50 00 00 00 00 30 10 00 00 00 00 00 00 00 00 00 00
70 01 00 02 40 00 00 00 00 00 00 00 00 00 00 00 00
80 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 1F 00 80 01 00 40 00 00 00 00 00 00 00 00
C0 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x27DA
Revision ID 0x01
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x00000400
Subvendor ID 0x1849
Subsystem ID 0x27DA
Int. Line 0x05
Int. Pin 0x02
PCI registers
00 86 80 DA 27 01 00 80 02 01 00 05 0C 00 00 00 00
20 01 04 00 00 00 00 00 00 00 00 00 00 49 18 DA 27
30 00 00 00 00 00 00 00 00 00 00 00 00 05 02 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Ethernet Controller
Location bus 3 (0x03), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8139
Revision ID 0x10
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000D800
Address 1 (memory) 0xFEAFFC00
Subvendor ID 0x10EC
Subsystem ID 0x8139
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI registers
00 EC 10 39 81 07 00 90 02 10 00 00 02 00 20 00 00
10 01 D8 00 00 00 FC AF FE 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 EC 10 39 81
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 20 40
50 01 00 02 76 00 01 00 00 00 00 00 00 00 00 00 00
Description VGA Controller
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x68F9
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xE0000000
Address 2 (memory) 0xFEBC0000
Address 4 (port) 0x0000E000
Subvendor ID 0x1682
Subsystem ID 0x3030
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Device type Legacy PCI-E Endpoint Device
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps class Vendor Specific
Caps offset 0x100
Vendor ID 1
Size 16
Caps class Advanced Error Reporting
Caps offset 0x150
PCI registers
00 02 10 F9 68 07 04 10 00 00 00 00 03 08 00 80 00
10 0C 00 00 E0 00 00 00 00 04 00 BC FE 00 00 00 00
20 01 E0 00 00 00 00 00 00 00 00 00 00 82 16 30 30
30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 82 16 30 30
50 01 58 03 06 00 00 00 00 10 A0 12 00 A1 8F 2C 01
60 10 29 09 00 01 0D 00 00 40 00 01 11 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 1F 00 00 00
80 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
A0 05 00 81 00 0C 30 E0 FE 00 00 00 00 61 49 00 00
100 0B 00 01 15 01 00 01 01 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 4 (0x04), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0xAA68
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x08
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEBFC000
Subvendor ID 0x1682
Subsystem ID 0xAA68
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x150
PCI registers
00 02 10 68 AA 06 00 10 00 00 00 03 04 08 00 80 00
10 04 C0 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 82 16 68 AA
30 00 00 00 00 50 00 00 00 00 00 00 00 11 02 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 82 16 68 AA
60 10 29 09 00 01 0D 00 00 00 00 01 11 00 00 00 00
A0 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
DMI
SMBIOS Version 2.5
DMI BIOS
vendor American Megatrends Inc.
version P1.80
date 05/18/2012
ROM size 1024 KB
DMI System Information
manufacturer To Be Filled By O.E.M.
product To Be Filled By O.E.M.
version To Be Filled By O.E.M.
serial To Be Filled By O.E.M.
UUID {03000200-0400-0500-0006-000700080009}
SKU To Be Filled By O.E.M.
family To Be Filled By O.E.M.
DMI Baseboard
vendor ASRock
model G41M-VS3.
revision unknown
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Processor
manufacturer Intel
model Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
clock speed 2933.0 MHz
FSB speed 267.0 MHz
multiplier 11.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 4096 MBytes
DMI Memory Module
designation DIMM0
size 4096 MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCIE1
type A5
populated yes
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4 GB
max# of devices 2
DMI Memory Device
designation DIMM0
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 4 GB
DMI Memory Device
designation DIMM1
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 4 GB
Storage
Drive 0
Name KINGSTON SA400S37240G
Revision S1Z40102
Serial 50026B73801EFB64
Capacity 223.6 GB
Type Fixed, SSD
Bus Type ATA (3)
Features SMART, TRIM
Volume c:\, 222.2 GBytes (69.1 percent available)
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC52B
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x045E, product=0x07FD
Graphics
Number of adapters 1
Graphic APIs
API D3D
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
ID 0x2000000
Name AMD Radeon HD 5450
Board Manufacturer XFX Pine Group Inc.
Memory size 2 GB
PCI device bus 4 (0x4), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1682)
Model ID 0x68F9 (0x3030)
Revision ID 0x0
Performance Level 0
Core clock 300.0 MHz
Memory clock 533.0 MHz
Performance Level 1
Core clock 400.0 MHz
Performance Level 2
Core clock 650.0 MHz
Win32_VideoController AdapterRAM = 0x80000000 (2147483648)
Win32_VideoController DriverVersion = 15.301.1901.0
Win32_VideoController DriverDate = 02/26/2016
Monitor 0
Model ZORAN HDMI TV ()
ID ZRN0294
Serial
Manufacturing Date Week 0, Year 2005
Size 23.0 inches
Max Resolution 1920 x 540 @ 60 Hz
Horizontal Freq. Range 15-46 kHz
Vertical Freq. Range 59-61 Hz
Max Pixel Clock 80 MHz
Gamma Factor 1.0
Software
Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 18362)
DirectX Version 12.0
Register Spaces
Register space PCI
Register space PCI #2
Register space SMBus, base address = 0x0400
Register space LPC, base address = 0x02E
You could've easily just posted your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
and then stuck on some images of CPU-Z.
The rams seem to to show to be running at 1064MHz. Have you tried working with more voltage on your rams> manually setting the speed and timing in BIOS? Speaking of BIOS, you might want to try and remove CMOS battery and replace it after 15 minutes.
Yes sorry this is my first time I didn't know how much info would suffice, I have tried setting the bios but it won't let me see the option for 1333 or at least I don't know how to unlock it. Would giving it more voltage not fry the ram? The ram says 1.5v max. I am also not familiar with setting the timing you mentioned
Increasing the DRAM voltage does not increase the memory clock speed. Leaving memory BIOS settings on [Auto} will give you conservative (SPD) Serial Presence Detect memory parameters. Leaving DRAM Frequency on [Auto} likely will not give you [667MHz DDR3_1333].
OC Tweaker Screen (page 28 downloadable manual)
In the OC Tweaker screen, you can set up overclocking features.
DRAM Frequency
If [Auto]is selected, the motherboard will detect the memory module(s)inserted and assigns appropriate frequency automatically. You may select[400MHz DDR3_800], [533MHz DDR3_1066] or [667MHz DDR3_1333].
Thank you for your response, I have tried setting it on auto setting also looked manually for the options listed and only see the first two 400 and 533 but no the option for 667 1333. When I leave it on auto and check the speed it defaults to 400HMz or 399 if I check with CPU-Z .
