GA-7N400 Pro2 Rev 1 SATA Problem
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I was successfully running a single WD 36GB 10k RPM SATA drive as the boot
disk (set to "BASE") on my GA-7N400 Pro2 board (Rev 1) for several months.
Then it started to get flakey recognizing the drive when booting. Would take
a couple of reboots to get past detecting the drive and on to booting.
Finally, Windows 2000 started getting errors when accessing the disk and the
system would crash.
I RMA'ed the disk back to WD. It was returned as "recertified" but is still
not recognized by the board. I suspect that the SATA controller has a
problem, but I have no other SATA drives to test with. I am on F5 and
briefly loaded F11 to no avail.
Has anyone else had an experience similar to mine? Any ideas on a fix?
John Bissell
"John Bissell" <bissell@nospam.alum.mit.edu> wrote in message
news:E0Hxd.4225$9j5.3940@newsread3.news.pas.earthlink.net...
take
the
> system would crash.
still
> John Bissell
Since the drive is ok, whats left?
cables-remove and replace
driver-reinstall
BIOS -reflash
Board - Go to the ver-2.
HG
> take
> the
> system would crash.
> still
Had the same problem,
It was the motherboard fcuk SATA channel
