G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hello,
I recently purchased a Ga-7N400 Pro2 motherboard and two sticks of
512Mb PC3200 DDR and an Athlon XP2500. On my first attempt to set up
this motherboard, the install of W2K kept bombing. In retrospect I
have learned a few things. For one, the chipset drivers are WAY out of
date. I didn't write down the BIOS version, but I suspect that it is
old also because it identified the CPU as "AMD AthlonXP 1900+" and set
the FSB to 400. The XP2500 is only available with 333 FSB speed.
Setting the FSB too high certainly could have caused problems.
I have downloaded all the latest drivers and the FI, FJ, and FK
versions of the BIOS. The version of W2K I'll be installing is SP2.
First, do you think I should flash the new BIOS, and, if so, any
suggestions as to which version?
Second, in order to be certain that the FSB is set to 333, am I
correct in assuming that I must set the clock multiplier switches to
the correct multiplier instead of auto and then set the memory
frequency in the Advanced Chipset Features menu of the BIOS setup?
Any other tips, suggestions, known issues are welcome.
Thanks!
Daryl
Hello,
Thanks!
Daryl
