GA-7VRXP Memory problems
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
I'm having problems adding an extra 512MB of memory to my 256MB
GA-7VRXP W2K/W95 dual boot system and would appreciate some advice.
I've tried three different types of memory, two lots of PC2700 and now a
strip of PC2100 (Kingston branded). In each case the symptoms are the
same; The BIOS recognises the memory and POSTs, Windows starts loading,
crashes partway through the process and the machine restarts. This boot
loop would apparently continue forever if I don't interrupt it.
At first I suspected a HAL issue but W95 (which doesn't have one)
experiences the same symptoms. I've tried using the BIOS 'Failsafe
defaults'; I've tried using different slots - with and without the
original memory and I've tried upgrading the BIOS (F12 - very
unreliable, lots of blue screens, so backed out). In every case the
symptoms are pretty much the same. Either the CHKDSK crashes while
still counting down (always in the same place, 10, 9, 8, 7, 6, bang!) or
occasionally, a BSOD ("PFN_list_corrupt",
"Driver_IRQL_not_less_or_equal", "KMODE_exception_not_handled" amongst a
selection) depending on the BIOS I'm using at the time.
On a couple of occasions I got the blue desktop background of a Windows
system starting up, but nothing happened (no "Loading Network Settings"
or "Security Settings" messages, keyboard and mouse apparently not
recognised) and I had to reboot.
I'm currently looking for a copy of the same brand as the original
memory (VData - found some on eBay); in the meantime, can anyone suggest
what might be going wrong? I'm puzzled because the board has been
thoroughly reliable since I originally built it.
Simon Elliott
I had the same problem with my GA-7VRXP when I bought it over 2 years ago.
I had started off with1 module of 512MB generic PC2700. A few months later
I decided to add another 512MB PC2700 module, also generic but different
manufacturer. I began having the same problems that you are currently
having. Each module would work fine by itself, but as soon as the second
module was added, even using the most conservative BIOS memory settings, the
problems started.
Running memtest86 with each module by itself confirmed that there were no
problems with either of the individual modules. After adding the second
module and rerunning memtest86 confirmed that there were memory errors when
both modules are used together.
The solution was to bring both modules back to my vendor and exchange them,
at no extra cost to me, for a pair of modules from the same manufacturer and
same production lot. With the 2 new 512MB PC2700 modules together, running
memtest86 for several cycles confirms that there are no more errors.
This motherboard seems to be very sensitive to any mismatches in memory
modules.
"Simon Elliott" <simon@deleteelliott.clara.co.uk> wrote in message
news:1093512885.20592.0@sabbath.news.uk.clara.net...
> Simon Elliott
>problems started.
>modules.
Thanks for the info Homer.
From my experience I would agree that the 7VRXP is unusually sensitive
to the memory installed. In my case I can't get it to recognise anything
other than the original memory, none of the new sticks I've tried
(including a stick of Kingston brand) have worked and I'm surprised I
ever managed to get the board working in the first place.
I'm currently looking for something matching the original memory and
hope to have some success with eBay.
In your case, what revision board do you have and what BIOS version were
you running at the time (if you can remember)? Is there a BIOS version
that's as stable as the F4 I'm currently running that might be
successful, the F12 I tried was useless?
Thanks again for your contribution. I've spent two weeks, on and off,
trying to get the board to accept some extra memory and it's good to
hear that it's not me doing something wrong - this board is very sensitive.
Simon
My board is Rev. 2.0, with BIOS F12.
I know that the Rev 1.1 and earlier boards were very problematic with
certain highend video cards (GeForce4's at that time) and PC2700 RAM.
news:1093598758.3960.0@a lovely person.uk.clara.net...
ago.
later
the
> >problems started.
when
them,
and
running
> >modules.
sensitive.
> Simon
Thanks Homer.
My board is Rev 1.1 and I'm currently using F4, I found F12 too
unreliable to use.
Goes to show you shouldn't believe everything you hear. My recently
purchased GeForce FX 5200 installed sweetly and has been rock solid in use.
Do you have any tips I could use to try and get this PC2100 working?
Simon
Hi, Simon.
Try the following manual memory settings, instead of letting the motherboard
read the memory timings from the SPD ROM on the memory modules:
In the Chipset Features Setup page of the BIOS Setup try the following
conservative memory settings...
Top Performance 😀isabled
Fast Command :Normal
Configure SDRAM by SPD 😀isabled
SDRAM Frequency :266MHz
SDRAM CAS# Latency :2.5
SDRAM Command Rate :2T Command
If you are able to get to the hidden settings by pressing <Ctrl> <F1> at the
main BIOS menu page and then going into the Chipset Features Setup page then
also try the following memory settings...
Precharge to Active CMD :3T
Active CMD to Precharge :7T
Active to CMD :3T
SDRAM Bank Interleave 😀isabled
SDRAM Burst Length :4 QW
ClkGen for DDR/PCI Slots :Enabled
The above memory settings should be more conservative than the Fail-Safe
Values.
news:1093619799.15409.0@nnrp-t71-02.news.clara.net...
> Thanks Homer.
> unreliable to use.
use.
> Simon
>Hi, Simon.
>Active to CMD :3T
>Values.
Thanks Homer.
I'll have a try with those and let you know how I get on.
Simon
>> Hi, Simon.
>> motherboard
>> at the
>> page then
>> Active to CMD :3T
>> Values.
Hi Homer
Followed your suggestions, but no success.
I tried using the Chipset settings you suggested but couldn't find the
'hidden settings' to change those. CTL+F1 does nothing on my board and
I'm wondering if this something that came in with either the Rev 2.0
board or just a later version of the BIOS (currently F4)? I've looked
but cannot find this info on the Gigabyte website.
I'm currently awaiting the end of an Bay auction to see if I can get my
hands on a stick similar to my original memory. If not then I'll try
Crucial, given they seem to have a money back guarantee.
Simon
Hi, Simon.
Do you know if your Rev. 1.1 board has the voltage regulation problem fixed?
A couple of years ago owners of the Rev. 1.1 boards RMA'd them and Gigabyte
repaired them and sent it back to them. The repair, if I remember
correctly, was the addition of a 4.7uF 30V tantalum capacitor on one leg of
a voltage regulator MOSFET next to the NB_FAN header.
Prior to the voltage regulation fix being available from Gigabyte some were
raising the AGP Voltage, DDR Voltage or VCore Voltage to get enough voltage
to the video card, memory modules or CPU respectively. This wasn't always
successful.
news:1093779413.13798.0@nnrp-t71-02.news.clara.net...
> >> Hi, Simon.
> >> motherboard
> >> at the
> >> page then
> >> Active to CMD :3T
Fail-Safe
> >> Values.
> Hi Homer
> Simon
>Hi, Simon.
>successful.
Good question Homer. Honest answer, don't know.
To my knowledge the board has never been RMA'd. I bought it new from a
fair a couple of years ago, as the basis of my current box. It's not
clocked but has worked quite happily with the optimum settings
I can find the NB_FAN socket but don't know what a voltage regulator
MOSFET looks like. Is it one of several chip-like things running down
the left hand side of the socket? I can't see anything that looks like
an extra capacitor. As you can guess, I'm working at the limits of my
knowledge here.
Thanks for taking the time to help me. BTW, hows Midge? 🙂
Simon
Hi, Simon.
Here's a link to a page with pictures of the fix...
http://mysite.wanadoo-members.co.uk/hoodspages/cap_mod.htm
news:1093870804.17238.0@spandrell.news.uk.clara.net...
> >Hi, Simon.
fixed?
Gigabyte
of
were
voltage
always
> >successful.
> knowledge here.
> Simon
>Hi, Simon.
I see what you're talking about and no, I don't have the fix. The board
is two years old, therefore too old to be RMA'd and this kind of work is
beyond me; so it sounds like something I'm going to have try and work
around.
Based on this and the information from your previous posting, I'm
guessing that my problem is a voltage issue. Presumably the three
different sticks I've tried have all been affected as a result. My
current hypothesis is that I might have some success using another 256MB
stick (complementing the one already in place), instead of 512MB and I'm
off in a minute to make the swap.
Your previous posting refers to "raising the .. DDR Voltage ... to get
enough voltage to the ... memory modules". If I find that the 256MB
doesn't work alongside my original (effectively meaning I can't add any
extra memory) then this increase is something I might consider. Can you
offer any advice about what sort of increments should I be trying and
anything else I should be aware of to avoid making a costly mistake?
Thank you again for your ongoing help.
Simon
The default DDR Voltage is 2.5V. The increments are by 0.1V. The maximum
DDR Voltage that you can select is 2.8V. This means that you have 3
different voltages that you can try.
If none of the DDR Voltage changes works, try raising the VCore Voltage to
+5.0%. You may have to try various combinations of DDR and VCore voltages.
Check your system's voltage status in the Hardware Monitor & Misc Setup BIOS
setup page and post them here.
news:1093944590.16817.0@ersa.uk.clara.net...
> >Hi, Simon.
> around.
> Simon
Simon Elliott wrote:
> I'm guessing that my problem is a voltage issue. Presumably the three
> 256MB stick (complementing the one already in place), instead of 512MB
> and I'm off in a minute to make the swap.
And what do you know? It works.
Swapped the 512MB for 256MB (also Kingston brand) and the computer boots
without a problem. In my case 2 x 256MB works where 1 x 512MB doesn't.
I can only conclude that Homer was on the right track, there is a
voltage issue with my board and that a 256MB stick is compatible, where
a 512MB stick isn't. I'm currently waiting on eBay, but I might be
getting a third 256MB stick and now I'm quietly optimistic that this one
will work as well.
Thanks again Homer for your help.
Simon
Thanks for the tips Homer.
I'd bought the extra memory because I was experiencing an occasional
'hiccup' in normal operation. If I had several applications running and
swapped between them quickly then the computer would hang for a couple
of seconds, CDs or radio would 'stutter' and then normal operation
would resume.
I attributed this to a memory bottleneck and time spent accessing the
swap file. Since I added the extra 256MB I've not experienced the
problem (fingers crossed).
So I'm happy with what I've now got and don't intend (in the near
future) to be adding any more memory; particularly if it's greater than
a 256MB stick.
So I've saved your previous posting for future reference and here's my
BIOS readings for academic interest.
AGP Voltage: 1.5V
DDR Voltage: 2.5V
Vcore Voltage: Normal
CPU Host Clock: (Mhz): 133
VCore: +1.728V
VTT: +1.184V
+3.300V: +3.264V
+5.000V: +4.865V
+12.000V: +12.224V
5VSB +5.886V
Thanks again for your help.
Simon
Your Vtt (memory termination voltage) at +1.184 V is low by more than 5%.
It is suppose to be ½ of the DDR Voltage (i.e. 1.25V). The Vtt on my Rev. 2
board is +1.248 V, which is low by 0.16%.
Too bad you didn't post the Vtt for the 512MB stick(s) when you tried them.
It most likely would have been lower than +1.184 V. This would definitely
point to a voltage regulation problem that needs to be fixed.
If you would have raised the DDR Voltage, with the 512MB stick(s) you've
tried, you probably would have been able to use it.
If you know someone who is an electronics hobbyist and can obtain and solder
that capacitor to your board, that would be the ultimate solution.
news:1094024254.8248.0@lotis.uk.clara.net...
>>voltages.
>>BIOS
> swapped between them quickly then the computer would hang for a couple of
> seconds, CDs or radio would 'stutter' and then normal operation would
> resume.
> I attributed this to a memory bottleneck and time spent accessing the swap
> file. Since I added the extra 256MB I've not experienced the problem
> (fingers crossed).
> So I'm happy with what I've now got and don't intend (in the near future)
> to be adding any more memory; particularly if it's greater than a 256MB
> stick.
> AGP Voltage: 1.5V
> DDR Voltage: 2.5V
> VCore: +1.728V
> VTT: +1.184V
> +3.300V: +3.264V
> +5.000V: +4.865V
> +12.000V: +12.224V
> 5VSB +5.886V
> Simon
That would explain a couple of blue screens I've had since I put the new
stick in, one on startup and one on shutdown (didn't bother recording
them, want to see if they become a regular occurrence first). Presumably
that's when the greatest load is placed on the machine.
Are those figures based solely on experience or do you have a reference
you could share?
Unfortunately, at the time I didn't know that sort of information would
have been useful.
I'd wondered if that might have been the case. I won't be looking for
any extra memory but if some comes my way cheaply then I might
experiment. Are there any risks of blowing components if the DDR voltage
is increased?
I'd like to see if those blue screens I mentioned become a frequent
problem. If so, then I might consider it. This box is my main computer
and I use it for my business, so I can't afford a long period of downtime.
Simon
DDR Memory Power specifications say that Vtt (memory bus tracking
termination voltage) is defined as ½ of the DDR reference voltage, which is
2.5 Volts. If you don't believe me you can do a Google on "Vtt memory
termination voltage" and read the Electrical Engineering specifications for
DDR memory power requirements. I have also taken Electrical Engineering at
university and I also have a degree in Computer Science.
You should be able to safely increase your DDR Voltage, even up to the
maximum of 2.8V, in the BIOS without damaging your memory modules. This
voltage increase doesn't have any effect on any of the other components on
your system board, just the memory bus. You currently have it set at 2.5V
but that is not what your system board is currently delivering to your
memory, my guess is that your memory is really getting about 2.37 Volts. I
would try setting DDR Voltage to 2.7V and see if your Vtt is any closer to
the preferred 1.25V. This should get you more stability.
news:1094105026.8820.0@nnrp-t71-03.news.uk.clara.net...
>>2 board is +1.248 V, which is low by 0.16%.
> you could share?
>>them. It most likely would have been lower than +1.184 V. This would
>>definitely point to a voltage regulation problem that needs to be fixed.
> have been useful.
> I'd wondered if that might have been the case. I won't be looking for any
> extra memory but if some comes my way cheaply then I might experiment.
> Are there any risks of blowing components if the DDR voltage is increased?
>>solder
> problem. If so, then I might consider it. This box is my main computer and
> Simon
Took your advice and googled on 'Vtt memory termination voltage' but
couldn't find a page I understood. Most of the places I found were
talking about various manufacturers products and required more
background knowledge than I have. What little I could understand seemed
to confirm what you're saying though.
Had another blue screen at startup yesterday, a Stop 4E,
PFN_LIST_CORRUPT. Googling led me to -
http://support.microsoft.com/?kbid=291806
which said "This behavior may occur if you have bad RAM.".
I don't believe this to be the case, although I'll run a memtest86
sometime, just to check. If I'm understanding everything correctly then
my DDR voltage is close to the point of instability and as you suggest,
increasing it should move my board away from this point.
I plan to monitor the frequency of these BSODs and if they become too
frequent to try increasing the DDR voltage and see if they go away.
Your advice that this is unlikely to damage my memory is reassuring.
Simon Elliott
I would expect that you are going to get a lot of memory errors or complete
system freezeup or spontaneous reboot when you run memtest86. You cannot
rely on the results from memtest86 when you are not supplying the correct
power requirements to the memory modules. You need to test the memory on a
known stable system board to determine if your memory modules are defective.
The DDR Voltages in the BIOS, that are above the standard 2.5V, are there
for the overclockers so that they can attempt to achieve system stability
when running their memory modules faster than its original design
specifications.
news:1094193229.17009.0@eunomia.uk.clara.net...
>>is 2.5 Volts. If you don't believe me you can do a Google on "Vtt memory
>>for DDR memory power requirements. I have also taken Electrical
>>Engineering at university and I also have a degree in Computer Science.
> couldn't find a page I understood. Most of the places I found were talking
> about various manufacturers products and required more background
> knowledge than I have. What little I could understand seemed to confirm
>>I would try setting DDR Voltage to 2.7V and see if your Vtt is any closer
>>to the preferred 1.25V. This should get you more stability.
> Had another blue screen at startup yesterday, a Stop 4E, PFN_LIST_CORRUPT.
> sometime, just to check. If I'm understanding everything correctly then my
> Simon Elliott
Thanks for the warning, makes sense. Details below, but I'm not
confident I can consider this board stable yet.
One thing puzzles me. Why do the problems seem to manifest mainly at
startup, occasionally at shutdown but not when Windows is running
normally? Almost always when the two initial Windows screens, the one
with the progress bars (or the CHKDSK screen) have just ended. I can
run the box on a full load (SETI screensaver) for several minutes, no
problem. Burn CDs, no problem. Occasions I might have guessed problems
would occur, but not so. Does the point at which the problem occurs tell
us anything about the hardware in the machine, or anything about what
Windows is doing as it starts?
Think about what what I've just written, it's when a screen mode changes
- low res to higher.
It's late, I'm tired and I readily agree I could be talking rubbish. But
aren't memory and an AGP graphic card on the same PCI bus? So might
lowering the AGP voltage also have a positive effect? Do they share the
same power line? The card is an Nvidia GeForce FX 5200, 128MB of memory.
It's just a thought, so be gentle with me if I'm talking b******s.
>specifications.
Are significant gains possible? Aside from SETI it's rare I max out my
CPU for any length of time. Occasional WAV or JPG editing needs it, but
most of the time I'm just ticking over. What are these guys doing that
they need the power? And are these systems reliable? Or is it just
because they can? No problem with that, by doing so they're helping me
as well. Just curious.
BSODs more frequent today, various types, half a dozen in total - four
just trying to start the box earlier this evening. So I increased the
DDR voltage to 2.6, then 2.7 volts before they stopped. Forgot to record
the Vtt value, will come back with that another time.
Thank you for taking the time to help.
Simon
The AGP bus and the DDR memory bus are both connected to th KT333
Northbridge chip. The PCI bus is connected to the VT8233ACE Southbridge
chip. So the answer to your question is no, the PCI bus is not on and not
the same as the AGP or memory bus. Notice that the AGP and DDR memory buses
are both connected to the same chip. The default AGP Voltage is 1.5V, you
cannot lower it, you can only raise it to 1.8V maximum by 0.1V increments.
When you say that an increase in video resolution seems to cause the
problem, that would point to the video card drawing more current as the
video resolution increases (more video memory on the graphics card being
used) causing the voltage to drop to both the video card and the memory
module(s). This would indicate that you really need to get that capacitor
soldered onto your board to solve this voltage regulation problem.
This motherboard can run the DDR memory synchronously at 266MHz (preferred)
or asynchronously at 333MHz. When overclockers increase the FSB beyond the
normal 266MHz this also increases the speed of the AGP bus (above 66MHz),
memory bus (above 266MHz), and PCI bus (above 33MHz). When the buses are
run beyond their original design specs the digital signals on the buses
start to degrade or become deformed from the ideal square wave and the
system is unable to tell the difference between a logical 0 and a logical 1.
It is the voltage level that determines a logical 0 or a logical 1. If the
digital signal on the memory bus transitions below the Vtt voltage then this
is a logical zero, if the digital signal's voltage is in the Vtt voltage
(1.25V) to DDR voltage (2.5V) range this is considered a logical one.
Overclockers will increase the DDR Voltage to "strengthen" the digital
signal on the memory bus. This is also the same reason for raising the
VCore Voltage for the CPU when overclocking. Overclockers usually overclock
because they can. The performance gains are usually noticable, otherwise
they wouldn't be doing it. Overclocking success and stability/reliability
are dependant upon the CPU model and the quality of RAM and good cooling of
the CPU.
news:1094253809.31201.0@nnrp-t71-02.news.clara.net...
>>complete system freezeup or spontaneous reboot when you run memtest86.
>>You cannot rely on the results from memtest86 when you are not supplying
>>the correct power requirements to the memory modules. You need to test
>>the memory on a known stable system board to determine if your memory
> Thanks for the warning, makes sense. Details below, but I'm not confident
> normally? Almost always when the two initial Windows screens, the one with
> the progress bars (or the CHKDSK screen) have just ended. I can run the
> box on a full load (SETI screensaver) for several minutes, no problem.
> Burn CDs, no problem. Occasions I might have guessed problems would occur,
> but not so. Does the point at which the problem occurs tell us anything
> about the hardware in the machine, or anything about what Windows is doing
> as it starts?
> Think about what what I've just written, it's when a screen mode changes -
> low res to higher.
>>specifications.
> Are significant gains possible? Aside from SETI it's rare I max out my CPU
> for any length of time. Occasional WAV or JPG editing needs it, but most
> of the time I'm just ticking over. What are these guys doing that they
> need the power? And are these systems reliable? Or is it just because they
> can? No problem with that, by doing so they're helping me as well. Just
> curious.
> just trying to start the box earlier this evening. So I increased the DDR
> voltage to 2.6, then 2.7 volts before they stopped. Forgot to record the
> Simon
Please excuse my late night ramblings then.
>module(s).
I follow you.
I would agree. I'm getting BSODs almost every time I start the box now.
It's like an old car on a winter's morning. You've got to turn it over
several times and eventually it will fire up. That's with DDR voltage maxed.
I follow you.
>the CPU.
That bothers me. I bought this board because, at Rev 1.2, I thought
"That's got to be fairly stable. They'll have ironed out the bugs from
the first version.". I don't want to overclock, all I want is a stable
board that delivers what it promises. And at the moment this isn't.
Gigabyte boards were ok by me, until recent experience. How do I know
the next board I buy is going to be reliable? I guess I'm going to have
to research the next purchase, rather than buy on whim.
Simon
It's a good idea to check the news groups before buying. You will get an
idea of what problems people are having with particular models. Or you can
post your questions or requests for an opinion on a particular board model
before you purchase, especially if the board is obsolete or f it is very
new.
news:1094327106.17874.0@eunomia.uk.clara.net...
>>buses are both connected to the same chip. The default AGP Voltage is
>>1.5V, you cannot lower it, you can only raise it to 1.8V maximum by 0.1V
>>increments.
>>module(s).
> I follow you.
>>This would indicate that you really need to get that capacitor soldered
> maxed.
>>(preferred) or asynchronously at 333MHz. When overclockers increase the
>>FSB beyond the normal 266MHz this also increases the speed of the AGP bus
>>(above 66MHz), memory bus (above 266MHz), and PCI bus (above 33MHz). When
>>the buses are run beyond their original design specs the digital signals
>>on the buses start to degrade or become deformed from the ideal square
>>wave and the system is unable to tell the difference between a logical 0
>>and a logical 1. It is the voltage level that determines a logical 0 or a
>>logical 1. If the digital signal on the memory bus transitions below the
>>Vtt voltage then this is a logical zero, if the digital signal's voltage
>>is in the Vtt voltage (1.25V) to DDR voltage (2.5V) range this is
> I follow you.
>>overclock because they can. The performance gains are usually noticable,
>>otherwise they wouldn't be doing it. Overclocking success and
>>stability/reliability are dependant upon the CPU model and the quality of
>>RAM and good cooling of the CPU.
> "That's got to be fairly stable. They'll have ironed out the bugs from the
> first version.". I don't want to overclock, all I want is a stable board
> that delivers what it promises. And at the moment this isn't. Gigabyte
> boards were ok by me, until recent experience. How do I know the next
> board I buy is going to be reliable? I guess I'm going to have to research
> Simon
>new.
Yeah, sorry, another late night rant on my part. Apologies
You're quite right, shop around and ask advice before buying.
BTW, two boots today and no BSODs.
Simon
