GA-8IEXP Beeps after removing NB Fan
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hi
I have a GA-8IEXP and I unplugged the NB fan because it started making
noise. After I unplugged it the computer wouldn't boot and beeped
continuously, so I reset the BIOS and got it to boot and work OK.
Today it locked up and my wife had to hard boot it and now it's doing the
same thing again, when it's turned on it only shows self test screen on the
monitor, beeps continuously and the power LED is flashing.
Any help will be greatly appreciated.
Thanks,
Joe
To state the obvious.....try plugging the fan back in again!
If the fan is noisy then you need to replace it or get a heatsink, you
can't just unplug it and expect your PC to work.
On Wed, 26 May 2004 21:08:28 GMT, "Joe Nord" <joenord@hotmail.com>
wrote:
>Hi
>Thanks,
>Joe
I have a 81EXP rev 1.2 and my fan has been unplug for over a year and
it's still running ok. I removed the fan and just left the stock
heatsink on it. Don't know why you are getting beeping?
On Wed, 02 Jun 2004 13:40:29 +0100, Guru #99 <guru99@gurusrus.gu.ru>
>wrote:
>>Hi
>>Thanks,
>>Joe
