I recently had a firmware update to the beta bios, or at least thats what I believe it was (stated firmware update). The bios update failed and after a Restart the PC with not post . MOBO LED error codes show " 0d" with the CPU error LED on, on the MOBO, which is not part of the error code list in the manual, or even on the official gigabyte website.
Everything worked fine until the update failed. I had my 3200 corsair ram rated properly as advertised, CPU OC'd to 3.9 from stock 3.6 voltages staying the same at around 1.30v- 1.35v. and my Zotac 1050 OC'd +200 coreclock and +500 memory clock. Everything ran fine from Day 1 no issues unlike what the threads and forum were blasted with. only thing I had issues with was XMP and that didn't bother me much.
I'm not sure you guys handle issues with failed bios update. But I have done everything I can think of,
-I have restarted, no change
-Cleared CMOS and restarted , no change.
-Cleared CMOS and removed CMOS battery no change.
-Cleared CMOS, removed battery and removed power for more than an hour. No change
-Removed all peripheral connections, i.e HDD's DVD/CD, GPU, Fan (barely any attached as this is a caseless PC build. rebooted no change
-Removed RAM and placed in each RAM slot one at a time and tested each stick of RAM.
-Re-seated CPU.
-Removed everything and breadboard tested MOBO, no change to 0d LED status. *No need to remove from case (caseless sysytem) to breadboard as it is basically a breadboard system.
-I cannot post from either main or backup Bios, receives 0d Error Code on both bios
- Tested post attempt with only CPU installed no change.
-Tested with CPU and on stick (switched after no post with first 1/2 of ram move to each ram slot, no change
- Attempted with both sticks in slots 1 and 3 no change, moved to 2 and 4 no change. 0d error code still displays
I have no other MOBO that supports my CPU.
I am at a complete loss on what esle to do other than RMA and use my warranty I purchased at the time of sale with PCOutlet
Current list of all installed parts in this build
-AMD - Ryzen 5 1600X 3.6GHz 6-Core Processor (OC to 3.9)
-Corsair - H60 54.0 CFM Liquid CPU Cooler
-Gigabyte - GA-AX370-GAMING 5 ATX AM4 Motherboard
-Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory
-Western Digital - Caviar Green 750GB 3.5" 5400RPM Internal Hard Drive
-Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
-Zotac - GeForce GTX 1050 2GB Mini Video Card
-Corsair - CX 600W 80+ Bronze Certified Semi-Modular -ATX Power Supply
Running Windows 10 Pro 64bit
-Re-seated CPU.
