GA H110M S2H TMPIN2 Overheat ? Help .
ChrisTsall99
702
Hello , can anyone suggest me an app from Gigabyte in order to see my motherboard's temperature ? I think that Hardware Monitor has a bug because my TMPIN2 is 30-40 Celsius but for 1-2 seconds it goes to 70-80 . So any other apps suggestions ? Thanks for your time !
Yes for the VRM, but are you absolutely sure that software can accurately read all your motherboard sensors? If you really are worried, have you checked using the Gigabyte tools?
Yeah totally normal ~40 Celsius but what do u mean by saying 80 Celsius for silicon ?
Thanks for your reply !
Components that get hot are made of silicon and they can sustain temperatures significantly higher than 80°C; unless you have issues, I recommend you don't worry too much about it.
Okay then , but what is TMPIN2 ? Is it the northbridge?
