GA Z170 D3H DDR4 - water cooler on cpu runs, psu fan runs, mobo inner leds on, but no post no BIOS
obrunomartins
7
Hello guys! I have search for several topics here but none solved my case.
Installed my GA-Z170-D3h rev1.0 and hooked up everything (intel i7 7700k, 2x Crucial Ballistic 8GB RAM 3000MHZ) when I power on the motherboard has its internal leds on, the watercooler installed on CPU runs apperently fine, the PSU fan runs, but nothing appears on displays (no BIOS). The keyboard leds numlock scroll lock keeps off.
The monitor is plugeg on onboard hdmi plug. No graphic card installed yet.
I have switched memory sticks between slots but still...
I notice the memory I installed is not on the Gigabyte Memory Support List, but it has the same specs of another supported RAM on the list.
I have reset mobo by removing battery before.
You can not without a 6th gen CPU. If possible, try returning the board and buying instead a B250 board. A local pc shop might also help.
Even Gigabyte says its 7th gen compatible?
I suppose this is not a home procedure... how can I do it?
I think B250 mobos only support 2400mhz ram and below. Is it right?
