What setails would you know?can i get some more details about whats happening such as what cable you are using to connect the pc to the monitor?
and is the io port for what you are plugging it in with loose in any way?
Nope tried that about 3 times still the same thingtry reseating the cpu, tell me if that works
Yep I even tried reseating gpu, RAM, then cmos but still nothingis everything seated in the slots correctly?
Have you any idea what BIOS rev. the board is on? Specifically, whether it is one that supports your CPU.Yep I even tried reseating gpu, RAM, then cmos but still nothing
