News Galax RTX 4090 Is the First GPU With an HDMI Retimer For Long Distance Connections
In a "global market", all of these products SHOULD BE available to anyone in the world! Too bad that market is not designed to promote anything but profit.
Hmmm, sounds very plausible. After all, he lists his 2 PhDs on his profile!
Maybe us peasants with double MAs should also do that, and throw in the AAs as well!
Galax has implemented the Parade PS8419, a 12 Gbps HDMI 2.1 retimer
That's only 1/4 the bit rate of HDMI v2.1, and less than the bit rate of of v2.0 (18 Gbps). At those data rates, is there even any benefit from retimers?
Also, in general, does it even make sense to have a retimer right next to the source? Shouldn't the signal be pretty pristine and non-degraded at that point?
Wow! Can you say anything about the cable you used?
According to this, there are some HDMI cables capable of 18 Gbps up to 50 feet, by way of a built-in boost/EQ chip:
BTW, I recommend that seller. They're no-nonsense cable geeks. I've bought several cables from them, including even a custom-made job.
Also, the wikipedia page on HDMI has a convenient table for relating resolution + refresh rate to data rate:
According to that, you can do 4k @ 8bpp at up to 74 Hz at 18 Gbps signalling rate.
I think I ordered it from Monoprice.
Reactions: TJ Hooker
