Alright so i am kinda confused about buying these 2CPU air coolers for my processor which is core i7 3770K (socket LGA1155 as i think)
in my country the Gamdias Boreas M1 610 is 675ounds and the cooler master is 750 (LED)but the point is Gamdias as stated by it is website description has more fan speed-air pressure-airflow-air pipes also i like its design more than the coolermaster but that air cooler is kinda new and i literally can't find anyone to give me some reviews about it also if these numbers are really true or is it just for marketing? and is it really better than the coolermaster? or should i go with the coolermaster as i am really worried about the no reviews thing (or if someone here is having it maybe he can give me an idea about it and if it is good or should i stick with the cooler master.
https://www.gamdias.com/component/index.php/en/cooling-1/boreas-m1-610-1#random
www.coolermaster.com
Note:i live in a country which temperatures can go up to 45
Hyper 212 LED Turbo
Hyper 212 LED Turbo provides the best balance between airflow and static pressure to take the heat away. Four Direct Contact heat pipes with funnel shaped aluminum fins optimize cooling for optimal CPU performance. Moreover, the improved universal bracket design ensures easy and worry free...
