Hi! I am new to the site. My name is Daniel...Dan for short...you guys have some really nice guides for newbies like me to help assemble PCs
I have come up with a budget build and i need you guys to take a look at it.
Before i list the components i should mention that in my city Asus is the ONLY choice basically due to limited or no support of MSI/Gigabyte/others.
Now i need a system to play games like fallout 3, crysis etc and mostly for web development which doesn't take a lot.
Phenom II x4 955 BE (really looking forward to overclocking it...maybe after the warranty is over lol)
for the mobo i have gone with the M3A78-EM which is based on the 780G chipset and has a PCIe x 16 slot. I save a lot of money if i get this mobo in place of the M4A78T-E or something similar based on the 790GX chipset. this way i can afford to buy a HD 4850 1GB card or the 1GB 9800GT card. the 790FX is way to expensive to even consider.
Ram is DDR2-800, 4GB (2x2GB)
Seagate 500GB 7200rpm Sata 2
18.5' LCD Samsung
650W Power supply (is this too much? too little? could really appreciate some guidance regarding this)
i will mostly overclock the 955 BE after 3 years (warranty expires) by then i should have a new PC as a backup if something horribly goes wrong. is the 780G a good overclocker? and is the above combination good for a budget build?
18.5' LCD Samsung
