games keep crashing and computer keeps "running into problems"
Jul 22, 2018
Whenever I play any of my games they crash after 20-30 min of play time. so much that I have started really monitoring the temps and all. But when it crashes the gpu temps are at 50-60, and cpu temps are 40-50. I've checked for any driver updates and windows updates and they're all up to date. This problem started occurring when i replaced my damaged hard drive with a new one but I cant see why that would be the problem. although my disk usage does like to peak to 100% most of the time. someone please help!
Specs
CPU: I3-8100
Motherboard: Z370-A PRO
Ram: G.skill ripjaws v 8gb (3200Mhz) GDDR4
HDD: WD blue 1tb
Graphics Card: Zotac gtx 1060 amp edition
Power supply: EVGA 500w
Case: Rosewill nautilus
The only problem is that the windows drivers might be corrupted. Just reinstall windows and make sure you have the latest nvidia drivers running. I had this problem too and this fixed it for me.
I dont think that having 3200 Mhz memory is the cause because even though i3 8100 supports only 2400 mhz the only think that that will happen with using a 3200mhz stick is that it will not give the performance boost.
