I've got a decent gaming computer, it's nothing spectacular though. I have a problem though where most of my games will run slightly slower than the set frame limit. I use frame limits to reduce the load on my GPUs, otherwise my games will run around 400 fps and heat up the cards. I prefer setting a frame limit over vsync because I get the dreaded input lag on most everything. The slight FPS drop causes major stuttering.
On Warframe, if I set the FPS cap to 60, I get 58 FPS. Set it to 72, I get 70. 144, 142.
Middle-earth: Shadow of Mordor has the same issue.
Minecraft
I don't have time to test more games, for I am a student and don't get to spend that much time on the computer during the school year.
I am running a preview build of Windows 10 (14971), however the version hasn't changed since before the problem started. This being said, I am unaware of any changes there, but I won't deny that there may have been one.
PC specs:
i7-4790k @ base clock (4GHz, although it turbos to 4.33)
16 GB DDR3
2-way SLI 960 2GB @ 1.5 GHz
I updated my graphics drivers recently, around the same time that my computer went to build 14971, so it was before the issue started. I will get the version number soon, Geforce experience doesn't want to open without a system restart. I know that can be an important factor in troubleshooting game performance.
Minecraft
PC specs:
16 GB DDR3
