Gaming build, need help
Combinekillz
35
Hello
This is a gaming build i put together and was thinking of purchasing, is there any improvements you would add or if im wasting cash at any of my choices.
I would like to be open to 2 way SLI and overclocking if possible and for the price to not go over more than £100-£200 if possible
Link: http://uk.pcpartpicker.com/p/QmNfGX
Many thanks
If you want an h100i and future SLI go for a full tower case. I have the Corsair 300r and there isn't enough clearence for the h100i. You'll also want at least a 750-850W PSU for SLI. Check out EVGA B2 or G2 power supplys.
don't know what your monitor choice is, but that being said if you stay around 23 inches you should be good. may want to plan ahead and get a 1000 w psu, incase you ever upgrade you won't need to buy another and you may want to use your m.2 to load you operating system on. so you will need a stick. that will insure fastest ops loading times
Latest posts
