Gaming keyboard combo and Usb hub
jazgreen99
95
Hi all I’m looking to buy a low budget gaming keyboard and mouse. any suggestions?i found two which looked pretty cool. Especially the keyboard because I multitask a lot. I would prefer wireless as I’ve always used but I don’t think there are any
Thermaltake Ttesports Challenger Prime Keyboard
The T-Dagger Sergeant RGB
Mouse.
Or the
Cooler Master SGB-3000-KKMF-1-US Devastator 3 Keyboard & Mouse Gaming Combo
Any suggestions for usb hubs?4 Ports or more with a long extended cable +-1metre .Do you get usb hubs with micro sd slots? aswell as a standard slot?
Never use cheap wireless keyboard and mouse, especially mouse. Except if all you want to do with it is farming simulator or minecraft. Otherwise, they are unrealiable.
Quality wireless however is sometimes even better than wired (because the cable doesn't hinder you but that is only for competitive gamers).
As for USB hubs I found you these:
https://www.aliexpress.com/wholesale?catId=708032&initiative_id=AS_20190204042053&SearchText=usb+hub+with+card+reader
2.0 USB hub 90cm with 6 port and card reader:
https://tinyurl.com/UsbHub2-0w-6ports-90cm
You can easily find really cool videos on keyboard and mice on youtube. Randomfrankp released a video recently where he showcases good mechanical keyboards under 50$. You could find those type of videos for mice as well. Rocket Jump Ninja used to make really good mouse reviews, but I haven't check in a while.
