Gaming pc Build Help
murchiej
5
Ok so i am really bad at pc but i have the basics down and all i need to know now is if my build has the right cables and the right sizes for all parts like the PSU and and if the fan will block my ram sticks really basic things iike that:
CPU
Intel Socket 1151 Intel - BX80677I77700K - Remove
Intel Core i7 7700K (Base:4.20GHz, Turbo:4.50GHz / 8MB / LGA1151 / Quad Core / 91W / Fully Unlocked / Without Heatsink/Fan / Kaby Lake)
AVAILABLE 3 year
Increase quantity
Decrease quantity
$439.00 $439.00
Motherboard
Intel Socket 1151 ASROCK - Z270 Pro4 - Remove
ASRock Z270 Pro4 MB, Z270, 4x DDR4, 2x PCIE3.0 x16, 6x SATA3, 2x Ultra M.2, M.2, 8x USB3.0, VGA, DVI, HDMI, ATX
AVAILABLE 3 year 1 $155.00 $155.00
Graphics
NVIDIA Gigabyte - GV-N108TGAMING OC-11GD - Remove
Gigabyte GeForce GTX 1080 Ti Gaming OC (Base:1544MHz,Boost:1657MHz), 11GB GDDR5X (11010MHz), PCI-E 3.0, DVI, HDMI2.0b, 3x DisplayPort 1.4, RGB Fusion
AVAILABLE 3 year
Increase quantity
Decrease quantity
$1,079.00 $1,079.00
Memory
DDR4 Corsair - CMK16GX4M2A2400C16 - Remove
Corsair Vengeance LPX 16GB (2x8GB), PC4-19200 (2400MHz) DDR4, 16-16-16-39, 1.2V, Dual Channel Kit, Black
AVAILABLE Lifetime
Increase quantity
Decrease quantity
$279.00 $279.00
SSD
SSD - 2.5" & PCI Express WD - WDS240G1G0A - Remove
Western Digital WD 240GB SSD, WD Green, SATA III, Read up to 540MB/s, Write up to 465MB/s, 7mm, WD SSD Dashboard
AVAILABLE 3 year
Increase quantity
Decrease quantity
$119.00 $119.00
HDD
HDD - 3.5" Drives Seagate - ST1000DM010 - Remove
Seagate 1TB BarraCuda HDD, SATA III, 64MB
AVAILABLE 2 year
Increase quantity
Decrease quantity
$69.00 $69.00
Case
ATX BitFenix - BFX-NOV-100-KKWSK-RP - Remove
Bitfenix Nova Black ATX Case, Window, No PSU, USB 3.0 x 1, USB 2.0 x 1
AVAILABLE 1 year 1 $59.00 $59.00
Power Supply
ATX SilverStone - SST-ST60F-ES230 - Remove
SilverStone 600W Strider Essential Power Supply, 80+, 120mm Fan, 1x ATX, 1x EPS, 2x PCI-E (8/6P), 4x SATA, 1x Floppy
AVAILABLE 3 year 1 $69.00 $69.00
212 cpu air cooler 55$
I am Australian btw so that why the prices might seem insane.
No to the MB, case, PSU and the SSD.
PSU far too low end for the kind of power draw is required; case too restrictive airflow for the kind of components that it is expected to cool; MB VRM is far too low end for what is expected of it (OC an 7700k) coupled with the low airflow case and you got a recipe for failing components in a year time; finally the SSD is a part of the DRAMless bunch that is only worth for an ultra-basic OS-only drive 120GB class, not the OS+1or2games 240GB class.
Is this possible?
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor ($370.00 @ Shopping Express)
CPU Cooler: CRYORIG - H5 Ultimate 76.0 CFM CPU Cooler ($69.00 @ PCCaseGear)
Motherboard: ASRock - Z370 Killer SLI/ac ATX LGA1151 Motherboard ($229.00 @ PLE Computers)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory ($229.90 @ Newegg Australia)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive ($122.00 @ Shopping Express)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($85.00 @ IJK)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card ($1069.00 @ Umart)
Case: Inwin - 503 BLACK ATX Mid Tower Case ($78.00 @ Umart)
Power Supply: Corsair - TXM Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($128.00 @ Shopping Express)
Total: $2379.90
Generated by PCPartPicker 2017-12-11 21:33 AEDT+1100
Go here and "build" your system. The tool will help with compatibility issues and will provide you a better way to list parts here on TH for additional advice:
https://au.pcpartpicker.com/
