Gaming System Build Compatibility Question
Tomarama24
15
The PC I am planning to build is:
http://uk.pcpartpicker.com/p/2FLph
I already have the Power Supply.
The issue I am having is with the motherboard and the graphics card as the motherboard is 30x30cm and the graphics card is 40x25cm and the layout of the motherboard LOOKS like it won't fit in the space it has.
So i'd like to know if they all these parts will fit together properly and work.
I would also like to know what people think and rate this motherboard as well.
One last thing is my PC case is big enough to hold all this I have checked and I was thinking of buying a case fan for it but I don't know which one I should get any help there would also be appreciated. Dimensions are 9cmx9cm on my case for fan.
from the looks of things the gpu may be extremely close or even touch the ram but i doubt it, i would look around on youtube for reviews of the board to see other people setup and compare, other than that things should work ok, also you never stated which case you have
I can't find the case I have on the internet, I bought it on a whim in a store near me a year ago. I do have some pictures of it when I was asking about if it's well ventilated.
http://tinypic.com/view.php?pic=dcassy&s=5#.UvyYu_l_t7o
http://tinypic.com/view.php?pic=105bc09&s=5#.UvyYvPl_t7o
http://tinypic.com/view.php?pic=34t2vlt&s=5#.UvyYvvl_t7o
The case is easily bigger than the graphics card.
Well it's only an extra £14, is it really that much better?
Well if it doesn't I can always buy a new case if needed.
