Gateway 1800 acting up! Help Please
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
I have a Gateway 1800CX Performance Computer which is about 3 to 4
years old. Over a period of the last month or so, it has started to
take a long long time from the time you press the power button until
it boots up and finally gets to the Windows XP main screen. I am
talking about 4 to 5 minutes sometimes. Also, during some of these
bootups, the screen will go black for about 3-4 minutes before it
boots up to the normal opening screen. Anyone know what this could
be?
I am running Windows XP. Originally it had Windows 98 then I used an
upgrade disk to get Windows XP Home. It worked fine for years and
now it is doing these things. Any help would be appreciated.
Housekeeping:
Is Windows updated with all critical patches?
Is your antivirus and your firewall software current and running?
Have you scanned for spyware (www.lavasoftusa.com, security.kolla.de)?
"Maria Brown" <mbrown2@rgv.rr.com> wrote in message
news:acbdg0davrd12hsglhs6tg3pv5l5i3cbi6@4ax.com...
> be?
