Hi all.
I purchased a Gateway LX6810 a little while ago. Later I upgraded the video card, sound card, power supply, added another hard drive, and put in more case fans. Gateway neglected to include ANY case fans, and the unit overheated often.
The problem I am having is with controlling the fans and the BIOS. Basically, there is no control available (through BIOS or Speedfan). They came out with a recent BIOS update (which I installed), and the only change I can see is the CPU fan runs at 3250 RPM instead of 1400 RPM. It appears to me that Gateway realized they built it wrong, so they increased the fan speed of the CPU.
Now it is loud and annoying. I can't change any of the speeds. Overheating is not an issue because I installed more case fans appropriately. My issue is with the BIOS and controlling fan speed. Is there any way around this? Can I flash the BIOS to unlock it? Am I doing something wrong?
I am contemplating just putting a new mobo in. I am sick of dealing with Gateway.
Any help would be greatly appreciated.
