geforce 920m overclocking settings
Overclocking anything in a laptop is a bad idea due to heat and power issues. However put that aside, its so weak even if you managed a 10% overclock without heat or power problems your still left with a super weak gpu. Another way of putting it is adding 10% to not a lot still leaves you with not a lot. You wont notice a difference
Yes, with MSI Afterburner
My settings = Core Clock 110 MHz (135 MHz Works fine too)
= Memory Clock 190 MHz (220 and more crash with high load)
Temperature with OC excellent, this GPU don't overheat a lot
In GTA V Great improvement of movement / fps
My laptop: ASUS X552MJ/CPU N3540 @2,16GHz - boost 2,66GHz/GPU NVIDIA GeForce 920M 2GB
