GEFORCE FX 5200 128mb v Geforce3 Ti200 64mb
smith
140
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
hi all, i know i asked about the ATI v my GF3 ti200. just looked at a system
on ebay and it comes with the FX5200, will i be best to keep my GF3 or use
the new FX5200 ?
cheers all esp shronk if ya know this one :)
It all depends on which 5200 it comes with. If it's a 128 bit card clocked
at 275/500 (the fastest 5200 made) then it will be a tad faster than the
GF3. Other 128 bit cards will come in a little slower (but may have better
image quality). If it's a 64 bit card then there is no question. The GF3
will be twice as fast.
Dave
"smith" <negativespam@nospam.com> wrote in message
news:aFbdc.393$pQ6.362@newsfe1-gui.server.ntli.net...
system
> the new FX5200 ?
"smith" <negativespam@nospam.com> wrote in message news:<aFbdc.393$pQ6.362@newsfe1-gui.server.ntli.net>...
> the new FX5200 ?
Depends, if the FX5200 is an Ultra..or a Non Ultra with 128bits memory
bus, then it will perform like a GF3 ti200
If though it's a FX5200 Non Ultra with 64-bits memory bus.... then...
then it will perform like a GF2 orso!
gf3
system
> the new FX5200 ?
On Thu, 8 Apr 2004 13:35:56 +0100, "smith" <negativespam@nospam.com>
>the new FX5200 ?
it depend on are fast your system is check out some benchmark at
futuremark.com just to get an idea.
>the new FX5200 ?
I wouldn't be in too much of a hurry to part with the GeForce 3 card
just yet. It may well outdo the FX5200 - and quite handsomely too.
Although the FX5200 is ok for someone moving up from maybe a GeForce
original or GeForce 2, I would say a GeForce 3 Ti200 might well make
it look silly... If you had a Ti500, I would say - definitely trash
the FX5200, so I am willing to bet that a Ti200 is only marginally
less in performance than the Ti500, whereas FX5200's have provided
only one thing amongst upgraders = Disappointment...!!!
Of course, not all FX5200's are created equally. There are bound to be
some which are better than others.. This also goes for GeForce 3 Ti200
cards too...
